Tips how to open oil drain plug - Snowblower Forum : Snow Blower Forums
post #1 of 29 Old 01-20-2015, 02:59 AM Thread Starter
Hi.
I have an Ariens Snowblower and I would like to change the oil.
I am keeping to this howto:
Snowblower Maintenance - Change Engine Oil, Clean The Spark Plug - Craftsman 9HP
The problem is:
I cannot get the oil drain plug open. It is not rusty, but won't budge.
I tried two wrenches, no movement.
The only thing that moves is the plug plus the attached pipe. But the pipe should stay in place.
I also tried WD40, no difference.
Could you give me tips how to open this plug? (Without destruction)
fospa is offline
post #2 of 29 Old 01-20-2015, 03:30 AM
Thanks (Given): 30
Thanks (Received): 40
You need a pipe wrench to hold the pipe while you turn the nut. Left loosey -righty tighty. Hold the pipe right and turn the drain nut left. I had this problem last year myself. Cheers !
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #3 of 29 Old 01-20-2015, 07:57 AM
Likes (Given): 48
Likes (Received): 74
And go easy on the torque when you reinstall the plug. It need to be tight, but it's not a car lug nut!
Some owners manuals might even list a torque spec, but to me that's a bit overkill.
Cub Cadet 2X 524 SWE
caddydaddy is offline
post #4 of 29 Old 01-20-2015, 09:03 AM
Thanks (Received): 57
Likes (Given): 425
Likes (Received): 139
I had to use vice-grips to hold the tube ( no room for any other wrench ) , some heat , and a long handled socket wrench . The cap on the tube had some kind of blue lock-tite stuff on it
Pipe thread paste when I put it back on
Phil
Ariens 2 foot SHO
1894 is offline
post #5 of 29 Old 01-20-2015, 09:18 AM
Ray 1962 10ML60's Avatar
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 23
If you do take the pipe out with the plug its no big deal, just going to be more of a mess. Then you can separate the plug from the pipe on a workbench or in a vice.
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
post #6 of 29 Old 01-20-2015, 11:21 AM Thread Starter
Thanks for the answers.
I forgot to mention: I did use a pipe wrench and an adjustable wrench.
And its a normal screw, as stated above.
fospa is offline
post #7 of 29 Old 01-20-2015, 12:47 PM
CarlB's Avatar
Thanks (Received): 29
Likes (Received): 66
I use teflon tape on mine and it will come off easier next time. Ps do not over tighten
CarlB is offline
post #8 of 29 Old 01-20-2015, 12:50 PM
Thanks (Given): 30
Just a tip the adjustable wrench usually will slightly open and start to round off the nut ,adjustable wrenches are usually a last resort, try to stick with closed-end box wrench if it's hexagon.. But if it's older square type then I do understand the adjustable.
post #9 of 29 Old 01-20-2015, 01:17 PM
Thanks (Received): 14
Likes (Received): 52
As 1894 mentioned, use vise grips to hold the tube. Works great.
CO Snow is offline
post #10 of 29 Old 01-20-2015, 03:13 PM
If you need more room to work you can always tip the blower into the service position and then remove the pipe as well. All the oil will run to the far side of the engine and won't come out the hole. Just be sure to replace it before tipping it back down.
As for the adjustable wrenches opening slightly, I always wiggled them while tightening the adjustment nut while they were on the fastener. I always felt that gave me a much tighter bite.
And yes, I had noticed a couple posts of people saying they had loctite on the nut on the end of the pipe and had to use heat. That just seems silly to me.
