tire loosing air -- fix a flat?? - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 02-02-2015, 08:11 PM Thread Starter
Can I use that stuff that comes in a can to seal the tire? Or how else can I fix the air leak?
wantboost is offline
post #2 of 16 Old 02-02-2015, 08:12 PM
Likes (Given): 1879
Likes (Received): 661
I am not a fan of fix-a- flat even if there is a tube in the tire
post #3 of 16 Old 02-02-2015, 11:04 PM
Thanks (Given): 30
Thanks (Received): 40
Why not.. I can't see a balanceing issue going slow slow right? Just remove the wheel to do it and don't use the whole can on such a small tire, and rotate it every way possible to distribute the liquid all over inside. Have to coat the whole inside surface.
Or, as an alternative, you can get a tube installed. That's more money but it's the "preferred"way to do it. Fix a flat is the "easy way" to see if you can take care of it.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #4 of 16 Old 02-02-2015, 11:10 PM
Thanks (Given): 173
Likes (Given): 451
Likes (Received): 1029
http://shop.advanceautoparts.com/p/v...=1910102Better
Get yourself one'of these kits. lots better than fix a flat.
post #5 of 16 Old 02-02-2015, 11:14 PM
Thanks (Given): 30
That's if you find a nail. Can't plug a slow leak around the bead or valve.
post #6 of 16 Old 02-02-2015, 11:14 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
My local independently owned tire and battery shop will install a tube inside a snowblower tire for $15 parts and labor included.
db130 is online now
post #7 of 16 Old 02-02-2015, 11:16 PM
Thanks (Given): 30
Now your talkin ' That's the preferred method. Unless a nail hole can be plugged
post #8 of 16 Old 02-02-2015, 11:51 PM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
You may want to take it off and put it in water to find out where it is leaking. It may be the stem. If so, it may just need to be tightened.
If you have a lot of dry wrought you may just want to install a new tube as suggested. It will be the most reliable.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #9 of 16 Old 02-03-2015, 05:04 AM
Likes (Given): 1879
I didn't say don't use the stuff but after eating up a rim of mine I'm no fan of that stuff
post #10 of 16 Old 02-03-2015, 05:18 AM
Likes (Received): 12
Best stuff I have ever seen is Slime. That green goop you get by the gallon at Wallyworld. That's the only thing that seals those corroded alloy rims besides breaking them down. Of course with a blower you would have to take the tire off anyways because no way would it ever get up around your rims edge if that was the case. I'd put it under water and see exactly where it's leaking first then you know. It might just be a crappy valve stem gut.
2002 Ariens 932-101
driz is offline
