sooty spark plug - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-02-2015, 09:37 PM Thread Starter
AJR
sooty spark plug
2 yo used snotek - last year problem starting - added gas stab and seaform - worked ok but only used 1 time - no snow.
this year when i turn the choke to run it sputters - turn it back and its runs ok for about 30 minutes and then dies out - pulled the plug - very sooty (carbon?).
purchased new plug - same problem - fouled plug after about 30 minutes.
any thoughts?
thanks
AJR is offline
post #2 of 5 Old 02-02-2015, 09:53 PM
Likes (Received): 82
You should try not to post double threads for the same problem
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 5 Old 02-02-2015, 09:57 PM Thread Starter
AJR
sorry - i wrote my question on word and copied it - then ended up looking at both sections not realizing that i pasted it - sorry - wont happen again
AJR is offline
post #4 of 5 Old 02-02-2015, 10:05 PM
Hey no biggie and you can ask any moderators to delete the thread. Thanks
Normex is offline
post #5 of 5 Old 02-03-2015, 11:39 AM
Likes (Received): 9
Sounds like you have a dirty carb that needs a cleaning or replacement due to needing the choke to run. But when using the choke it produces too rich of a mixture then fouls the spark plug with carbon. Clean or most easy and cheap is to replace the carb. Check around I think they are relatively inexpensive.
Whimsey
whimsey is offline
