gas cap replacement - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-03-2015, 10:12 AM Thread Starter
Likes (Received): 41
gas cap replacement
I've been reading on some of these threads about gas caps causing venting/running issues. I was just wondering for those of us with older units, is there a generic replacement out there?
topher5150 is offline
post #2 of 5 Old 02-03-2015, 12:49 PM
Thanks (Received): 17
Likes (Received): 62
I have a better suggestion. I had a vented cap that failed which would cause the engine to die. It would run fine with the cap loosened. If the cap was tight the engine would die but in the process of dying, I could loosen the cap and it would run fine
I put a sewing needle in a pair of vice grips and heated the needle until it glowed. Then I melted a tiny hole in the cap with the needle. It's been fine ever since and no issues with water getting in the tank.
It's cheaper than replacing the gas cap.
CO Snow is online now
post #3 of 5 Old 02-03-2015, 03:16 PM Thread Starter
I'll have to give that a try...any time I get to use fire with something on the fuel system makes for a pretty good day
post #4 of 5 Old 02-03-2015, 03:49 PM
Thanks (Given): 30
Thanks (Received): 40
Just remember to take the gas cap off and do it on the workbench
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #5 of 5 Old 02-03-2015, 11:57 PM
Thanks (Given): 10
You could also just drill a very small vent hole in the cap. Worked for me.
90trunk is offline
