Tecumseh Engine Model # - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-03-2015, 03:30 PM Thread Starter
I have an older MTD 5/24 snowblower with a tecumseh snowking engine. I have been having issues with power loss under load. I cleaned the carb, governor works properly, so i was just going to replace the carburetor but cannot find the engine model number anywhere on the engine/snowblower. The owners manual i have is for models hsk30, hsk35, hssk40, and hssk50. Where can i find the correct model number, I just want to be sure I pick the correct replacement carburetor? Thanks everyone!
username is offline
post #2 of 5 Old 02-03-2015, 03:42 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Welcome to SBF username !!!
That has to be one of the most creative handles on the entire internet!
Engine model number is usually on the shroud...if your engine has electric start, it is probably under the start button assy.
Often times when the engine is a dog under load, it's a compression issue...commonly attributed to valves &/or bad head gasket. Are you able to check compression?
Check out Dave C's thread.
('87 Toro 38150 826)
classiccat is online now
post #3 of 5 Old 02-03-2015, 03:44 PM
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
It may be on top of the engine shroud on the sheet metal begin the plug. If you have an electric start, the start button assembly may be screwed down on top of it. Or it may be on an ID plate or sticker on the side of the shroud.
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
post #4 of 5 Old 02-03-2015, 03:46 PM
Thanks (Given): 24
Likes (Given): 15
Whoops, sorry for the dupe post, that's what happens when we post at the same time!
Ray
1962 Ariens 10ML60
1979 Toro 524
post #5 of 5 Old 02-03-2015, 03:59 PM
As a starting point, it should be HSSK50 since you say your MTD is 5 HP.
