Rough running 24" MTD 310-600A Snowblower - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 02-04-2015, 01:01 PM Thread Starter
I bought a 24" MTD 310-600A back in February, 1982. 33 Michigan winters at two houses with large drives have been rough on the beast but it has served us well; I have done quite a bit of maintenance over the years to keep it running but have been pleased, overall.
The last few years it has been running rough - I had the carb rebuilt and it did not seem to be helping. New spark plug and clean gas with Seafoam does not seem to help either. It takes about 3-4 minutes of the electric start to get it going, it surges while running and occasionally loses power or stalls. While it cleared the last 16" snowfall, it was difficult.
Engine is a 5 HP Snow King HS40 or HS50 (per the original manual, can't find info on engine).
I'm thinking that I should just replace the carb for $30 from Amazon (and add a filter, anyone have a link to one they like for this size engine?). While I am at it, any other suggestions of what I should consider?
Suggestions very welcome. I'm about to go fire it up in a few minutes and, while I expect to clear the drive, I know the experience will be annoying.
wayne47 is offline
post #2 of 17 Old 02-04-2015, 01:59 PM
If your engine is a single shaft engine that for $100 stick one of those Harbor Freight Predator 212cc engines on there. If yours has the extended camshaft for the drive wheels then that will not work so well.
If you go with the change the carb method be sure to change the fuel line too. 1/4" ID available at any auto parts store for $1.00 - $1.50 per foot.
post #3 of 17 Old 02-04-2015, 02:09 PM
You don't want an air filter on a snow blower. No dust to worry about, but they can get wet and freeze.
TooTall9957 is offline
post #4 of 17 Old 02-04-2015, 03:07 PM Thread Starter
Sorry, I meant fuel filter. This motor drives the wheels as well.
wayne47 is offline
post #5 of 17 Old 02-04-2015, 06:44 PM
HJames's Avatar
Likes (Received): 11
New carb may help, but some of your symptoms suggest the valves aren't seating properly. This will make for a hard starting engine that doesn't produce the same power. If your comfortable doing a valve job your problems can be solved in an afternoon for the cost of a gasket.
HJames is offline
post #6 of 17 Old 02-04-2015, 06:54 PM
404
Thanks (Given): 45
Likes (Given): 53
Likes (Received): 10
Engine part number is at the top of the fan shroud. Under the electric starter button if you have one. Stamped in.
404 is offline
post #7 of 17 Old 02-05-2015, 10:04 AM
Thanks (Given): 15
Likes (Received): 14
Check the compression on the engine. If it's good, a new carb might be the ticket. If not, you'll have to deal with exhaust valve clearance. BTDT recently, with the help and guidance of the fine folks on this forum.
Craftsman 5/22 with impeller mod & poly skids,
Ariens 28+ Deluxe 921037 AX291
Dave C is offline
post #8 of 17 Old 07-28-2015, 03:58 PM Thread Starter
Looks like I need to do the valve job. Can I get a pointer to what is involved? I'm comfortable with mechanical repairs but not experienced with small engines.
wayne47 is offline
post #9 of 17 Old 07-28-2015, 04:15 PM
Thanks (Received): 173
Likes (Given): 414
Likes (Received): 663
this should get you started
post #10 of 17 Old 07-28-2015, 09:06 PM
tdipaul's Avatar
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 329
Likes (Received): 362
+1 on the re-power
The original engine has earned its keep.
1989 John Deere 1032
tdipaul is online now
