simplicity h1528e chute deflector problem - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-04-2015, 01:14 PM Thread Starter
I have a simplicity h1528e with the electric chute. The chute turns left and right fine but the chute will no longer go up. It was moving fine down but the deflector won't go up anymore. It would work going up sporadically last snowstorm we had but won't go up at all anymore. Somebody please help, we have more snow on the way!
hokymn is offline
post #2 of 3 Old 02-04-2015, 01:38 PM
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
Is's likely a switch issue or motor issue. If it were me I would look at the motor for the deflector and see if it's easily removed. Probably just a couple of bolts and unplug connection. Bring the motor in and let it warm up. that way with the motor off you could see if it goes up and down manually. Could just be iced up. You could also
try blowing very low heat like a hairdryer on the motor and see if that helps.
Zavie is online now
post #3 of 3 Old 02-05-2015, 07:15 PM
Had the same problem after Boston's Blizzard. This is a frozen worm gear if it appears to move (motor will seem to lift). This work for me Cup of warm water and WD40.
Wipe excess off
Pour water on worm gear then spray with WD working into the screw (worm) drive. Make sure chute hinge is not frozen as well. WD that also.
Work in the WD real well. 40inches in 4 days and more on the way.
CremeStout is offline
