Ariens 824 Slamming Sound when Auger Engaged - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 02-07-2015, 12:11 PM Thread Starter
Hi there,
Thanks to anyone who can help me out, I'm very new to snowblowers. My landlord left one for us to use, and it worked great about 5 times and then I noticed that it started making a noise when I would engage the auger. Sort of a slamming sound. It got worse and worse in the next few minutes and then I stopped using it. The link below is a video of it happening at right about 1.5 seconds. The auger is still spinning and I've checked that it's not hitting anything. Any help before tonight's big storm would be appreciated. Thanks!
comtois is offline
post #2 of 27 Old 02-07-2015, 12:17 PM
Likes (Received): 1377
sounds like a auger belt needs a looksee at.
post #3 of 27 Old 02-07-2015, 12:19 PM
is the machine brand new??????????? then it is just the belt engaging.
post #4 of 27 Old 02-07-2015, 12:20 PM Thread Starter
I took off the belt cover and removed the auger to get to the belts. They lok fine to me and the were replaced at the beginning of the season, so only 5 uses so far.
I also checked the idler arm and that looks ok as well, but it's adjusted all the way so that you get the highest tension when you engage the auger.
It is not brand new, it has been used for 2 previous winters. It was fully serviced at the end of last season, new belts, spark plug, oil change, etc.
The video doesn't truly demonstrate how loud the noise is. It's so loud when it engages that it actually hurts my ears. It didn't do that the first five hours of use. Not even slightly.
comtois is offline
post #5 of 27 Old 02-07-2015, 12:23 PM
then it is the sound of engagement you are hearing. not the best sound but it is doing what needs to be done. so to sum it all up. ALL IS GOOD IN THE HOOD. ROCK ON THERE!!!!!!!!!!!!
post #6 of 27 Old 02-07-2015, 12:24 PM Thread Starter
I'm going to go use it for a few minutes and I'll report back.
Thanks!!
comtois is offline
post #7 of 27 Old 02-07-2015, 12:26 PM
Thanks!!
All RIGHTY THEN.
post #8 of 27 Old 02-07-2015, 02:04 PM Thread Starter
Unfortunately I think there is a real problem here. When I engage the auger it makes a slamming sound, and then is quiet again until I hit snow. When that happens it starts slamming and whining. It sounds like maybe an auger belt issue?
comtois is offline
post #9 of 27 Old 02-07-2015, 02:14 PM
TRY loosing up that belt. just for kicks. check to see if there is any slop in that auger bearing. lift up and down on the shaft .
post #10 of 27 Old 02-07-2015, 02:15 PM
Check out the gearbox for the auger. The gears may have lots of play/be stripped.
AandPDan is offline
