Engine swap - Snowblower Forum : Snow Blower Forums
post #1 of 23 Old 02-08-2015, 08:57 AM Thread Starter
Thanks (Given): 24
Likes (Given): 37
Likes (Received): 14
Engine swap
Hi all, I have a Deutz-Allis 828 ,was having carb problems just ordered a replacement but have been looking at replacement engines as a backup. I see some of the engines are sold with no throttle control ,a seller says mount,pull cord and blow snow. Some of these are the Briggs and Stratton snow series engines I saw some of these engines on lawnenginesurplus.com , would they work? Thanks Kensico
Kensico is offline
post #2 of 23 Old 02-08-2015, 09:07 AM
Just measure the important things of your engine and then look at the diagrams of the replacement engines. It would be best to get something with the same crankshaft diameter, height and length as well as the same mounting pattern where it bolts on the tractor. The new OHV engines tend to be a little wider than the flat heads so you might run into issues on the left side of your blower if your crank handle goes through there.
Thanks Kensico thanked for this post
post #3 of 23 Old 02-08-2015, 09:15 AM Thread Starter
Thanks (Given): 24
Likes (Given): 37
Thanks for quick reply I am trying to find diagrams for my engine now regarding mounting holes I have a tecumseh hm80-155209K engine on it the LH358XA with 3/4" shaft looks like it will fit,e-mailed the seller it is a fixed speed motor with no throttle and was wondering about that part the no throttle.
Kensico is offline
post #4 of 23 Old 02-08-2015, 09:39 AM
Thanks (Given): 15
Personally, I wouldn't want an engine without a throttle. I like to idle down sometimes without shutting the engine off. However, that's how a lot of machines are now - full throttle only. It's your call.
Craftsman 5/22 with impeller mod & poly skids,
Ariens 28+ Deluxe 921037 AX291
Dave C is offline
post #5 of 23 Old 02-08-2015, 09:41 AM Thread Starter
Thanks (Given): 24
Likes (Given): 37
Yeah I'm worried about throwing a rod if it's at full throttle all the time.
Kensico is offline
post #6 of 23 Old 02-08-2015, 09:50 AM
Likes (Received): 1378
YA sure the BRIGGS will work just fine. you can still find some with the throttle on the engine it self.
post #7 of 23 Old 02-08-2015, 09:54 AM Thread Starter
Thanks (Given): 24
Likes (Given): 37
I saw a new 10hp tecumseh on Ebay for only $179 good deal but it has no throttle
Kensico is offline
post #8 of 23 Old 02-08-2015, 09:59 AM
step away from the ads. you do not want to go that route. YA FOR SURE.
post #9 of 23 Old 02-08-2015, 10:00 AM Thread Starter
Thanks (Given): 24
Likes (Given): 37
Yeah gonna check out some engine sites,Thnx
Kensico is offline
post #10 of 23 Old 02-08-2015, 08:37 PM
Thanks (Given): 10
Not sure if you are firm on a winter engine, but a lot of people (including myself) have repowered with the Harbor Freight Predator engines. They do the job, and the 6.5 hp motor has plenty of power and is incredibly affordable at $99 with a coupon.
Saewoody is offline
