Low Compression Tecumseh H70 130003 - Snowblower Forum : Snow Blower Forums
post #1 of 37 Old 02-12-2015, 01:44 PM Thread Starter
Good Afternoon,
I am trying to bring back an old snow blower. Its an Ariens snow blower with a Tecumseh H70 130003 engine. I have replaced the Carb, head, exhaust and intake gaskets, cleaned the valves; lashed and lapped them. Before i lashed and relapped the valves i got 88 PSI compression, however now i get about 60 PSI and the engine wont stay running at all. Before i got it running but at high speeds it would sputter and backfire, thats when i lashed the valves based on someones recomendations(exhaust to .012 and intake to ~.010) However now it wont run and my compression greatly decreased. Any help would be awesome.
Thanks,
Tim
gr0leau is offline
post #2 of 37 Old 02-12-2015, 01:56 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Welcome to SBF Tim!!!
is that 60psi using the recoil? if so, that's not-terrible / not-great...on a starter, you could do better.
Did you coat the new metal head gasket? I've been using the Permatex Copper head gasket maker...2 coats is plenty. Also, make sure you torque to 200 inch-lbs and in the proper order...then re-torque after a few heating/cooling cycles.
For the bad running, have you had the flywheel off to make sure you don't have a sheared flywheel key...throws off the timing? It could also be that the carb just isn't set properly...I understand that it's tough to set it properly if it won't run long enough...I would try leaning-out the mixture a bit to see if it performs better. Idle-jet is in play when you're not under load & the governor is set properly; high-speed / no-load throttle position should be barely off of the idle throttle position. That throttle is probably bouncing around like crazy...again making it tough to tune.
('87 Toro 38150 826)
post #3 of 37 Old 02-12-2015, 02:03 PM
Likes (Received): 42
Hi gr
Welcome to the Forum. Make certain that your cylinder head bolts are properly torqued to 200 inch lbs( 16.5 foot lbs.). Also, recheck yor valve clearances. You lapped your valves. Did you check your clearances at top dead center with both valves closed? You are leaking somewhere. You need to retrace your steps. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #4 of 37 Old 02-12-2015, 02:13 PM Thread Starter
That 60 PSI is with the starter, was 90 with the starter. I had the fly wheel off when i rebuilt the magneto, and the key looked good. It was also stuck in there, couldn't pull it out with my fingers but didn't try with any tools because i didn't really need it out.
gr0leau is offline
post #5 of 37 Old 02-12-2015, 02:15 PM Thread Starter
Originally Posted by motorhead64 View Post
Hi gr
I did lash the valves and lap the valves at TDC
gr0leau is offline
post #6 of 37 Old 02-12-2015, 02:25 PM Thread Starter
Hi gr
I didn't torque the bolts just did hand snug, but i was going to go get a new crank case gasket in case that was in, maybe i will get a new head gasket, (Ive opened it up like 4 times now) and try to torque them down.
gr0leau is offline
post #7 of 37 Old 02-12-2015, 02:26 PM
Like I said, you will need to backtrack. Everything you did should have improved compression...or at least left it the same. You erred somewhere....most likely on your valves. Did you end up grinding your valve stems to get the proper clearances? MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
post #8 of 37 Old 02-12-2015, 02:34 PM Thread Starter
Yeah I ground down the valve stems. The exhaust was at about .004 and the intake had no clearance.
gr0leau is offline
post #9 of 37 Old 02-12-2015, 02:53 PM
CarlB's Avatar
Thanks (Received): 35
Likes (Received): 81
thats a little strange that the intake valve had less lash then the exhaust to start with. I think .010 is a little big for the intake. You probably have a leaking head gasket. Replace the head gasket and torque to correct inch pounds and in the correct sequence.
CarlB is offline
post #10 of 37 Old 02-12-2015, 02:55 PM
http://www.asos1.com/tecumseh4hp/Tecumseh.pdf
Change out the head gasket and torque in proper order to specs. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
