Power Shift 824 Reverse Question - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 02-13-2015, 01:35 PM Thread Starter
Thanks (Received): 8
My Powershift has this little [occasional] quirk when using reverse. I almost always use R1 to back it up, but once in a while if the driveway is not icy, I'll use R2 even though it's a little fast for my liking. The question: There seems to be a spot I'll hit once in a while if I'm not holding the shift lever to the extreme position in the slot: (right for R1 and left for R2): I'll seem to get the equivalent of an "R3" speed. It's fast! (Too fast to keep engaged.) I'll reselect R1 or R2 and all is well again until the next random time this happens.
Is this an adjustment issue or a symptom of normal wear? I have the manuals, and neither the transmission adjustment or troublehsooting section mention this. Hoping it's an adjustment I can make.
Unit: 1997 Toro Power Shift 824. Never abused and always TLC'd for 17 years.
Thank you,
Chris
SnowdIn is offline
post #2 of 12 Old 02-13-2015, 01:57 PM
Likes (Received): 1379
you are going to have to adjust the reverse cable under the dash using 2 half inch wrench's. on those jam nuts.
post #3 of 12 Old 02-13-2015, 01:58 PM
let me know the score on that 1.
post #4 of 12 Old 02-13-2015, 02:33 PM Thread Starter
Much appreciated!! Glad to hear it's not "old age" that's causing the problem.
I'll check that cable and and try to adjust it for correct operation and report back on the results.
SnowdIn is offline
post #5 of 12 Old 02-13-2015, 05:13 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
PS93 is the expert and it might just need an adjustment.
BUT . . . since it sometimes does it and sometimes doesn't maybe it's something else. There is also the chance that the friction wheel isn't sliding on it's shaft smoothly and it's getting jerked past that R2 location and sticking there. You'd notice it's a bit stiff shifting gears.
You might want to set it up on it's auger and pull the transmission cover and check if the shaft the friction wheel slides on is in fact slippery and not gummed up or rusty. Over the years the lube can get hard and sticky or if totally neglected can rust.
I use a light film of synthetic wheel bearing grease (Mobil1) but some prefer to use oil.
Here is "Show and Tell" :
post #6 of 12 Old 02-13-2015, 05:24 PM
Here is "Show and Tell" : https://www.youtube.com/watch?v=VgHH_Tcufx4
they have a geared transmission in them. no friction wheel. there is a pulley in the front of the trans. but no wheel.
post #7 of 12 Old 02-13-2015, 06:06 PM
Thanks (Given): 30
Thanks (Received): 40
One more possibility is that the rod from the gear selector (under the dash) down to the trans has been reinstalled backwards or on the wrong side of the linkage (would be an easy mistake) and it's throwing it off just enough ?
What do you think PS93 ?
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #8 of 12 Old 02-13-2015, 06:18 PM
THAT can be checked to. but more than likely that cable has to be adjusted if replaced. on a 17 year old machine. those cables will wear out. a lot of people don't think they do or will. the reverse is done with the cable. not the rod. the shifter rod goes like this N,1,2,3,4 in a straight line. just like the POWERSHIFT feature the bell crank makes the reverse magic happen. you all getting me on this 1.
post #9 of 12 Old 02-13-2015, 06:48 PM
Thanks (Given): 30
Yes indeedie. And thank you.
I was pointing that out cause' mine was on backwards hehe. Things still functioned but the gear positions were not perfect.
I'll be using the PS again sunday as we are due for another foot with lots of wind so some drifting. Fluff/blow factor will be high and I'll get the ski-mask out for this one.
post #10 of 12 Old 02-13-2015, 06:53 PM
BETTER there than here in the paradise city. I got enough of it in my garage there BROTHER PF13
