Gas cap vent frozen? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-14-2015, 11:58 PM Thread Starter
Thanks (Given): 10
Is anyone else having a similar problem? Here in CT it has been below freezing for essentially the last month. My snowblower is kept in an unheated garage. It hasn't had a chance to thaw.
I was clearing a few paths the other day in the yard, and the machine was looking for gas. I loosened the gas cap a bit and the problem went away. I replicated this several times just to be sure. After that I just ran with the gas cap loose.
It makes sense to me that some snow got on or in the cap vent and then froze in between uses. Does that make sense to you guys. I figure if it becomes a bigger issue I can warm it up with a hair dryer.
Any feedback confirming my thoughts or other helpful information would be appreciated. Thanks. Also, if it matters, the engine is a 212cc predator from harbor freight.
Thanks again.
Saewoody is offline
post #2 of 8 Old 02-15-2015, 01:59 AM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
How old is your Predator? My engine has a rubber tube from a fitting in the gas tank to the air intake so the gas tank vents into the air box area. Does yours have a hose from the top of the gas tank to the air box assembly?
GustoGuy is offline
Thanks Saewoody thanked for this post
post #3 of 8 Old 02-15-2015, 03:41 AM
Yanmar Ronin's Avatar
Thanks (Given): 100
Thanks (Received): 83
Likes (Given): 81
Likes (Received): 404
Bring the cap in the house overnight to thaw out and dry out, and see if that helps. If it's just frozen that should fix you up (until next time).
Rubberband some tinfoil or something, or a board and brick, whatever, over the filler hole while it's off to keep stuff out/gas vapor in.
Yanmar Ronin is offline
post #4 of 8 Old 02-15-2015, 11:02 AM Thread Starter
Thanks (Given): 10
It does. I never gave it any thought that the tube was the actual
vent. I am just accustomed to the cap itself having a vent. I can't see where the tube leads to right now because I have to remove my make shift heater box. I've got some snow to clear today, I'll pull the heater box after that.
Saewoody is offline
post #5 of 8 Old 02-15-2015, 10:24 PM
Thanks (Given): 50
Likes (Given): 70
Attachment 41929
Check to make sure that the hose is not being pinched by your heater box. The hose attaches to the airbox assembly into the area before the actual throat of the carburetor. That could solve your problem since it should vent the tank of an overpressure as well as a low pressure. If it is blocked or kinked you will end up with a low pressure which will eventually affect gasoline flow.
GustoGuy is offline
post #6 of 8 Old 02-16-2015, 10:29 AM
Likes (Received): 41
Has anyone tried modifying or replacing the gas cap with something different? Would a valve cover breather from a car's engine work in place of a gas cap?
topher5150 is offline
post #7 of 8 Old 02-16-2015, 12:28 PM Thread Starter
Thanks (Given): 10
Good eye and good thinking. But that was not the issue. I had crimped that clear out of the way when I installed it. It had run with no problems in a few previous storms.
The problem did not occur yesterday, so I am guessing something thawed out. If it happens again I will pull the heater box.
Thanks for the responses.
Saewoody is offline
Thanks GustoGuy thanked for this post
post #8 of 8 Old 03-07-2015, 12:52 AM
Likes (Given): 103
Likes (Received): 21
I've successfully found a fix for this problem on my Tecumseh gas tank with a plastic vented cover. The snow would fill the vent area of the cap and plug it up, thus creating a vacuum in the tank and stopping fuel flow to the carb. I use a paint spay can cap and cut a vent hole inside to allow air flow to the fuel caps vent. I then press the cap onto the fuel cap and it shields it from snow blowing over and around it. Have not had an issue since.
~Ray~
~1975 Canadiana 1026 Heavy Duty w/light & limited slip differential (& custom exhaust (need to fabricate manifold), customized impeller housing, removable chute in about 5 sec) (currently out of service)
~ Craftsman 8/25 Trac-Drive C950-52671 (mid 80's ???) (current user) (replaced blown engine with original, now in service again)
~ Craftsman 12/32 OHV 71-52112-1 (now in service)
~Noma GP 1028EL (repaired and serviced for daughter to use)
RAYAR is offline
