Ariens 926LE - Engine problem - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 02-15-2015, 03:33 PM Thread Starter
Hi all,
Dealing with another New England blizzard. Used the snowblower for 2+ hours when my neighbor said it started to make a noise. He turned it off. When we tried to start it, it wouldn't start and we noticed a distinct noise.
It has oil. Has gas and compression. When I pull the cord, it takes some work to pull. Sometimes the engine catches and it gets easy but it makes the noise and won't start. Wondering if maybe something is frozen. Any ideas? I'm hoping the engine isn't shot.
Below is a video. You can click to play and hear it.
Thanks in advance for any advice.
___________________
Ariens 926LE
zup28w is offline
post #2 of 15 Old 02-15-2015, 03:43 PM
I'm thinking that maybe there is something under the engine shroud or a problem with the recoil mechanism/starter.
How hard is it take the shroud off and look at it?
AandPDan is offline
post #3 of 15 Old 02-15-2015, 03:56 PM
Likes (Received): 11
can you take it in somewhere warm and let it thaw out for a bit. Ive had belts growl at me like that. does sound like the starter pawl dragging the cup.
BeerGhost is offline
post #4 of 15 Old 02-15-2015, 04:06 PM Thread Starter
@ AandPDan - I wasn't sure if it was the starter/recoil because the noise began when it was already running. It does recoil all the way back. I could try to take it off and look. Normally it starts on the first pool.
@BeerGhost - We dragged into back into the shed and letting it sit there. I'm not sure how much warmer it will be. Unfortunately no garage area and the weather is going to be 18 and below the next few days.
___________________
Ariens 926LE
zup28w is offline
post #5 of 15 Old 02-15-2015, 05:12 PM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3359
Likes (Received): 682
To me it sounds like the auger belt is engaged and putting stress on the motor. I would pull the belt cover, disconnect the spark plug lead and observe what is going on with the belts. Could be ice is part of the problem. It does not sound like an engine problem to ME and If everything looks good, try the electric starter. If any unusual noises, shut it down immediately.
post #6 of 15 Old 02-15-2015, 06:16 PM Thread Starter
Hi Grunt,
I removed the belt cover and tried my best to hold a flashlight, a phone, and pull the cord. It definitely seems like the noise is coming from under the belt cover. I just don't know what to look for.
I can confirm that the auger doesn't seem to be engaged. If I pull the auger lever, I see the auger idler move and the belt tighten. Otherwise, the belt appears loose.
The drive gear does not appear to be engaged. I can push the snowblower forward and backward. When I press the level to engage the drive, I can't budge it.
Below is the video. Sorry if it's a bit jerky.
___________________
Ariens 926LE
zup28w is offline
post #7 of 15 Old 02-15-2015, 06:49 PM
Thanks (Given): 276
Likes (Given): 3359
It looks like the drive belt (the one closest to the engine) is spinning on the pulley and creating the noise. You will have to remove the belly pan on the bottom of the blower to see what is frozen or binding in the friction disc area.
post #8 of 15 Old 02-15-2015, 10:37 PM Thread Starter
Hi Grunt,
Thanks for the response. Just so I'm clear, when the engine is started, the engine sheave (looking at my manual) should spin, but there shouldn't be any tension/resistance on the traction drive belt or the attachment drive belt. I remember seeing that the attachment belt wasn't tight. Can't remember the drive belt. Too busy trying to not freeze my fingers off.
I do remember seeing that the friction disc is not engaged. It's maybe an 1/8" of an inch away from the drive plate assembly when not engaged. When I stand it up and take off the bottom plate, I'll hopefully have a better view.
___________________
Ariens 926LE
zup28w is offline
post #9 of 15 Old 02-15-2015, 11:10 PM
The drive belt should always be turning. The drive clutching happens at the friction wheel. The augers on the other hand handle the clutching at the belt.
post #10 of 15 Old 02-15-2015, 11:20 PM
Thanks (Received): 22
Likes (Received): 38
I would recommend isolating the problem by removing the belts and then see where and what is causing the noise. I also noticed in your second video, the edge of the drive sheave is very shiny and clean in relation to the rest of the drive components. Something tells me there's the problem.
all3939 is offline
