Craftsman 1150 model suddenly quits - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-15-2015, 07:35 PM Thread Starter
This is a Craftsman 1150 model. (tank sticker) Actual model # on frame is 31as6weg779.
It starts on half a pull, runs great for anytime from 15 minutes to a couple of hours and then will suddenly die like you hit the kill switch with no warning. Will not restart until left for hour or two then starts again like new.
It has no throttle and has been doing this since the day I bought it new. Any ideas whats causing it?
NEWENGLANDPETER is offline
post #2 of 4 Old 02-15-2015, 07:52 PM
Thanks (Given): 587
Thanks (Received): 769
Likes (Given): 4352
Likes (Received): 1734
Welcome to the forum
You should check to see if the gas cap is venting properly. If it's plugged up the engine will run for a while and then die.
How long have you owned it and have you ever brought it in to have someone check it out while it's still under warranty ??
post #3 of 4 Old 02-15-2015, 08:40 PM
Likes (Received): 11
could be a coil heating up n cutting out
BeerGhost is offline
post #4 of 4 Old 02-15-2015, 10:30 PM
Thanks (Given): 30
Thanks (Received): 40
Any chance the wire to your key switch get damaged ? may be intermittent. Just another possibility.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
