Toro 824 identification - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 02-15-2015, 11:13 PM Thread Starter
The sticker to identify my Toro is gone. It has 3 forward and 2 reverse settings using a hand lever. The carburetor has a threaded adj for the fuel mixture and no dump valve, one idle mixture screw and one idle setting screw.
What is the hose that comes from the manifold and drips oil for.
Canuck is offline
post #2 of 7 Old 02-15-2015, 11:21 PM
Sounds like the breather hose. Not really suppose to drip oil, but it can happen if the drains get clogged, the machine is tipped, the piece is installed upside down or the rings are really bad.
post #3 of 7 Old 02-16-2015, 04:06 AM
Likes (Given): 1888
Likes (Received): 668
you could probably identify the year of your machine by the serial number of the motor
Likes Molly2175 liked this post
post #4 of 7 Old 03-16-2015, 09:29 AM
I see you seem to be a Toro guy. You have the 8/24 XL highlighted on your list of blowers. Is there a reason you've highlighted it? I have a couple of old (1985-1971) 8 hp. Toros', along with a 6/24 with Powershift -1995. I like the old blowers because they will just eat snow. But the moveable scraper blade leaves a lot of snow behind. The 6/24-Powershift is under powered for deep 15-20" snow. It still keeps on chugging, but could use more hp. I'm not a fan of the power shift system, which is why I noticed the you had highlighted the successor to it. The 8/24 XL.
Molly2175 is offline
post #5 of 7 Old 03-16-2015, 10:14 AM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
Welcome to the forum Canuck
Since you don't have it's numbers the next best thing is to post pictures of it. The engine can help nail down a year but only if it's the original engine.
Molly, just send him a PM please as it's specific to him, off topic and doesn't really add anything to the thread
post #6 of 7 Old 03-16-2015, 12:24 PM
yours is more than likely an 824 model 38080 like mine with a tecumseh hm80
post #7 of 7 Old 03-17-2015, 05:17 AM
Likes (Given): 1888
my xl824 is a powershift also. I had talked to a guy with an xl 824 powerthrow and forgot all about it, he only wanted $250 for it but the powershift was only $100. the powershift feature isn't really needed and I've never used it. my favorite toro's are my 2450E and 521E as for the powershift I just wanted something with more power
