Ariens 724 - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 02-16-2015, 07:31 PM Thread Starter
Ariens 724
I have an ariens 1973 724 snowblower and can't get it to throw snow mor than ten feet. I live in New England and we have gotten about 7 ft of snow in the last month and a half HELP
Fireguy is offline
post #2 of 7 Old 02-16-2015, 07:35 PM
Likes (Given): 1879
Likes (Received): 661
hello fireguy, welcome to SBF!! does you 724 have belts dating back to 1973
post #3 of 7 Old 02-16-2015, 08:05 PM
Thanks (Given): 10
Also, consider doing a search for an impeller kit. That may take care of some issues as well. But detdrbuzzard makes a good point; if your belt is slipping your impeller can't do it's job.
Saewoody is offline
post #4 of 7 Old 02-16-2015, 08:21 PM
Thanks (Received): 194
Likes (Received): 816
Check the Impeller Bearing. A New Bearing can make a difference as well.
Jackmels is online now
post #5 of 7 Old 02-16-2015, 09:10 PM
Based on your recent snowfalls,,,,a 724 maybe too small for the job ? But, first you should decide if the engine rpm's are bogging down or not....when unable to throw good..
suspicionofignorance2 is offline
post #6 of 7 Old 02-17-2015, 01:17 AM
Thanks (Given): 30
Thanks (Received): 40
The engine should run between 3500-3600 rpm full throttle,govenor should kick in and not allow the engine to slow too much, belts should be in good shape and engage to grab well without slipping.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #7 of 7 Old 02-17-2015, 06:16 AM
Likes (Received): 42
Improvement also can be realized by making sure your impeller housing and discharge chute are smooth and coated with silicone spray or like lubricant. Sanding with 150 grit will remove rough spots where rust can grab snow and slow it down. M H
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
