Tecumseh 5.5 hp leaking oil out of left side - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 02-17-2015, 12:05 PM Thread Starter
Changed the oil a couple weeks ago. Started it today and noticed oil pouring (forget leaking) out of the left side of the engine. Immediately shut it down, checked dip stick and oil level is too high, so I overfilled it. I am using the right oil. A couple of questions if anyone can help:
1. What kind of damage could I have done?
2. Should I change the oil and refill to proper level and start again? Or should I just bring it to a mechanic to be on the safe side?
Thanks for your help!
-Rob
LordSloth is offline
post #2 of 12 Old 02-17-2015, 12:18 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
-Rob
Welcome to SBF there Rob!
Hopefully it was just oil pouring from the crankcase breather.
How much did you overfill by?
('87 Toro 38150 826)
Thanks motorhead64 thanked for this post
post #3 of 12 Old 02-17-2015, 12:34 PM
WestminsterFJR's Avatar
I would drain it to the correct level, remove and clean the spark plug, and run with it.
-Ken
2011 John Deere 1330se
WestminsterFJR is offline
post #4 of 12 Old 02-17-2015, 12:34 PM Thread Starter
Hi Classiccat,
Thanks for the quick reply! Unfortunately, I do not know the exact amount I overfilled it by, but the oil level is past the top of the full on the stick. I used the entire bottle of Ariens 5w-30, so 32 oz was in there before the issues.
-Rob
post #5 of 12 Old 02-17-2015, 01:00 PM
Likes (Received): 42
Rob
Get a 12 oz soda bottle and stick a funnel in it. Put it under the drain pipe and drain til it's full. You'll be good to go. As Ken said, clean or replace your spark plug. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #6 of 12 Old 02-17-2015, 03:38 PM Thread Starter
Everyone,
Thanks for the help, I'll let you know how it goes.
-Rob
post #7 of 12 Old 02-17-2015, 06:55 PM
Thanks (Given): 66
Likes (Given): 139
Likes (Received): 27
Rob -- the biggest challenge will be putting the drain plug back on while you've got oil coming out! Put a drain pan and newspeper under the drain, so you don't make a mess.....I'm speaking from experience on this point!
gsnod is online now
post #8 of 12 Old 02-17-2015, 06:59 PM
Thanks (Given): 587
Thanks (Received): 765
Likes (Given): 4344
Likes (Received): 1731
That and don't do it with hot oil !!
Cold oil will drain slower but be easier to cap.
post #9 of 12 Old 02-18-2015, 01:47 AM
Everyone,
-Rob
I think it's the governor shaft where you got the leak from... ask me how I know
Rockadode is offline
post #10 of 12 Old 02-18-2015, 02:15 AM
Thanks (Given): 66
Likes (Given): 139
Rockadode -- I'm interested in hearing more about this possible oil leak from the governor shaft.....may I ask you to share?
gsnod is online now
