lubricants - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 02-18-2015, 03:31 PM Thread Starter
Thanks (Given): 16
lubricants
what lubricant do you guys use for the wheel axles and the hex shaft can i use just white lithium grease or something else
cub cadet 3x is offline
post #2 of 11 Old 02-18-2015, 03:46 PM
Likes (Received): 42
A "low temp" rated lithium grease is ideal. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
Thanks cub cadet 3x, Bob J thanked for this post
post #3 of 11 Old 02-18-2015, 03:59 PM
Thanks (Given): 173
Likes (Given): 457
Likes (Received): 1032
+1 on the lithium grease. Been using it for years and years. Clean your hex shaft w/a rag and some type of solvent and smeR a very light film of lithium on it. While your i there clean off the drive platter and drive wheel.
Remove wheels and clean/grease axles w/lithium grease.
Thanks cub cadet 3x thanked for this post
post #4 of 11 Old 02-18-2015, 08:08 PM
Thanks (Received): 7
Last time I had my wheels off and wiped down my axles, I did so with a regular #2 grease. Doesn't seem like the type of grease is particularly critical here.
But wait, isn't lithium a soap? Isn't lithium grease less resistant to wash-out than most other greases? Why not use a marine grease which will be highly resistant to moisture?
I'd still like to find this stuff ... but doubt I will any time soon:
https://www.mystiklubes.com/do/product/GREASE/665027002
2011 Ariens 28 Deluxe
Bror Jace is offline
post #5 of 11 Old 02-18-2015, 08:16 PM
Thanks (Given): 173
Likes (Given): 457
All I know is I 've been using it for a long time and have never had a problem with lithium. Have a pound tub of it that I've been working on and still have about 1/3 of it left. Probably last my lifetime. I'm happy with its performance. There are different lithium based greases. Most are very good water/moisture resisters.
post #6 of 11 Old 02-18-2015, 08:25 PM
Thanks (Given): 30
Thanks (Received): 40
Someone here (forget who) had recommended Mobil1 synthetic grease, that seems ideal as it doesn't wash out and it's very cold weather rated. I have used lithium in the past, works well but washes out and needs to be replanished from time to time. I am going to pick up the synthetic and switch over myself. Just thought I'd pass it along
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #7 of 11 Old 02-18-2015, 08:57 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
I'm one of the Mobil1 synthetic believers. Stays "soft" to a lower temp. For the couple extra bucks a tub it just makes sense to me but I use synthetic oil in the engine too.
There are also guys who recommend oil as they think grease can get too stiff but it's worked for me.
I do oil the bushings though as I hope it helps them last longer.
post #8 of 11 Old 02-18-2015, 09:12 PM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
Marine grease is waterproof and very tacky. It's what's used on trailer wheel bearings. A lot of people here use this on locations that will frequently get wet like the wheel axles.
For the axle use what is in my grease gun. Usually a standard #2 wheel bearing grease. Check it every year and re-grease. Never had any issues.
If you run with both wheels locked you could use anti-seized. You just want to make sure the shaft does not rust to the wheel.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
Post Thanks / Like - 3 Thanks, 0 Likes, 0 Dislikes
Thanks cub cadet 3x, dbert, gsnod thanked for this post
post #9 of 11 Old 02-19-2015, 06:10 PM
+1 great stuff, a little goes a long way.
12111
NY Toro is offline
post #10 of 11 Old 02-19-2015, 06:16 PM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
12111
Yes the Mobile 1 grease is good too. However I use Amsoil marine grade grease. Very water resistant and lubricates well.
GustoGuy is offline
