Hungry Tec 5 hp eats carb butterfly - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-18-2015, 05:36 PM Thread Starter
K so I'm working on an old Tecumseh 5 horse to see if I can get it going, there was evidence of someone being into it before I got it and it would start only with full choke and rev like mad once running, governor wasn't working, neither was the throttle or adjustment screws, couldn't figure it out...
So I started checking over all the linkages etc. everything looked fine except when I looked inside the carb throat and moved the throttle I couldn't se the butterfly moving, so off comes the carb.
I took it off and lo and behold inside the intake manifold is the butterfly of the carb wedged in there, screw was nowhere to be found that secures it to the throttle shaft, I'm thinking oh no this thing is toast.. the screw got sucked in and beat the bejeezus out of the combustion chamber and valves etc.
Off comes the head and shrouds, valve spring cover etc, to my astonishment there was no damage to either the valves, head, piston, cylinder, or valve seats - no screw, anywhere!..., checked the muffler, tapped it, nothing. where the **** did that screw go? lol
Anyways cleaned everything up, new gaskets coming, working on the carb rebuild now, have spare parts and junk carbs to pick from so no issues there but I was wondering about the high speed needle screw on the bottom of the carb, what is it supposed to be set to? 1.5 turns out like the rest or is it different?
thanks
Rockadode is offline
post #2 of 4 Old 02-18-2015, 05:43 PM Thread Starter
IN case you guys were wondering , yes I've found a replacement screw to fasten the butterfly back on and it will get the red loctite treatment and curing before it gets put back in
post #3 of 4 Old 02-18-2015, 05:51 PM
Thanks (Received): 238
Likes (Received): 608
You do have to wonder where that screw went, don't you. Could be who ever took it out to begin with didn't put it back in.
1.5 turns sounds right to me, unless somebody else knows better.
post #4 of 4 Old 02-18-2015, 06:43 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2045
Likes (Received): 517
Dang man! Was expecting to see chattermarks all over that thing! Maybe the last owner lost it during a carb rebuild and superglued the butterfly to the shaft
Correct on the starting adjustment....1 1/4 on the idle and 1 1/2 on the main.
Thanks Rockadode thanked for this post
