Hahn Snow King auger - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 02-19-2015, 08:51 AM Thread Starter
just got a hahn snow king . problem is in heavy snow auger just stops. belts fine chain seems fine. when machine is [f auger spins freely and sprocket turns along with chain. Anybody have any ideas. Also need manual cant find it anywhere. Thanks
spanishsilver is offline
post #2 of 6 Old 02-19-2015, 09:32 AM
Likes (Received): 42
Hi S.S.
Welcome to the Forum. Could be your auger belt is stretched and is slipping under load...or, your worm gear in the gearbox is badly worn. Lastly, if it was a shear bolt problem, you have 2 that are gone. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #3 of 6 Old 02-19-2015, 09:41 AM
don't know the machine, but imagining the sprocket is on a shaft.
Is the shaft turning along with the sprocket?
If not, is there a broken key on the shaft for the sprocket?
you'd have to remove the sprocket to find out.
NY Toro is offline
post #4 of 6 Old 02-19-2015, 10:16 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
On your model, is the auger driven by a chain from the right wheel?
I had one many years ago that worked that way. There was a "slip clutch" between the wheel and the drive sprocket - I think its purpose was to allow the auger to stop without damaging anything if something got caught in it.
If yours has the same setup and the clutch is broken or got grease or oil in it (it relies on friction and grease/oil would make it slip), it could explain the problem you're having.
ELaw is offline
post #5 of 6 Old 02-19-2015, 10:46 AM Thread Starter
yes it is driven by a train from the right wheel. I still need to get the manual so I can figure it out. I will take wheel off this week and let you know. Is that clutch readily available.
post #6 of 6 Old 02-24-2015, 07:51 AM Thread Starter
Does anyone have this manual in PDF they can email or message me. cant findnit anywhere
