Tecumseh valve job hssk50 successful....now hunting - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-22-2015, 08:21 AM Thread Starter
finished the Hssk50 valve job.....excellent
did carb kit too
runs strong and powerful.........like new.
seems to be hunting mildly.......governer settings are same as before
high speed adjust gets rid of most of it........but not all
any tips?
DANMAN is offline
post #2 of 8 Old 02-22-2015, 09:25 AM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
You may have a vacuum leak, causing a lean condition. You can spray some carb cleaner around the gaskets for the carb and intake manifold. If it smooths out, you found the leak.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #3 of 8 Old 02-22-2015, 10:07 AM
Thanks (Given): 15
Likes (Received): 14
The troubleshooting guides point to fuel delivery issues. If you don't find anything obvious, a new carb can be had from Amazon for about $20.
Craftsman 5/22 with impeller mod & poly skids,
Ariens 28+ Deluxe 921037 AX291
Dave C is offline
post #4 of 8 Old 02-22-2015, 10:35 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
If its only hunting at high-speed / no load (goes away once the engine gets something to chew on)...then your idle may be too lean. Either you still have some restriction and/or the jet may need a tweak. Did you soak the carb in cleaner or just clean the jets and spray at things that seem important when you had it apart? There are passages in the carb body that can be restricted.
classiccat is online now
post #5 of 8 Old 02-22-2015, 10:37 AM
Thanks (Given): 231
Likes (Given): 2041
....and kudos to a successful valve job!!! Alot of people throw away perfectly good motors because of simple valve issues.
Likes Ariens1976 liked this post
post #6 of 8 Old 02-22-2015, 01:24 PM
Thanks (Received): 17
Likes (Received): 79
did carb kit too
any tips?
if you had the governor completely apart, it may be a governor setting, or the float is set too high on the lean side.
1967 S-242 Snowbird 4/24
Gilson 55012 8/26 gear drive
Ariens 910010 8/32
Cub Cadet 268 8/26
Yard-Man Snowbird 7040-0 5/22
Ariens 10M-L35 3.5/24
greatwhitebuffalo is offline
post #7 of 8 Old 02-22-2015, 04:31 PM Thread Starter
Appears the low idle tweak got rid of it. Thanks
Yes valve work intimidates most
My exhaust valve wasn't seating....symptoms were high rpm and no power......plus 20 years old.......
Pulled the 8 head bolts and confirmed....i could rotate the exhaust valve head by hand at just past TDC
had to grind /remove .015 off the valve stem tip to get to the nominal .008 preferred gap between valve stem end and cam lifter
Used Dremel tool w/abrasive stone.
I lapped the valves while I was in there
Total cost
5.00 head gasket. Don't try to reuse
5.00 valve lap compound
9.00 lap tool w/suction cup
8.00 carb rebuild kit with new hi low screws
I should have made a video...but no time in snowy upstate ny
Parts can be had cheap on ebays if you are not in hurry
Danman
DANMAN is offline
Thanks classiccat thanked for this post
post #8 of 8 Old 02-22-2015, 06:13 PM
Thanks (Given): 231
Likes (Given): 2041
Total cost
Danman
Glad you got that sorted-out DANMAN! Thanks for reporting back!
('87 Toro 38150 826)
