sno-tek 920404 chute crank lube? - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 02-23-2015, 11:47 AM Thread Starter
The directional crank for the discharge chute on my ariens sno-tek model 920404, has become very tight and difficult to turn. Does anyone know how to lube it? I can't seem to find anything about this in the owner's manual.
RickGP is offline
post #2 of 6 Old 02-23-2015, 12:24 PM
Thanks (Given): 587
Thanks (Received): 769
Likes (Given): 4352
Likes (Received): 1734
My guess would be you might have some corrosion/rust at the bottom of the discharge chute where it rotates against the auger housing. Might want to try to get some oil or grease between the two and work it back and forth a little to see if it helps.
post #3 of 6 Old 02-23-2015, 12:47 PM Thread Starter
Thank you K4F. I'll look at it later today.
RickGP is offline
post #4 of 6 Old 02-23-2015, 08:13 PM
Loosen nut #22 above.
post #5 of 6 Old 02-27-2015, 05:21 AM Thread Starter
thanks shryp,
that was the problem.
RickGP is offline
post #6 of 6 Old 02-27-2015, 09:19 AM
Likes (Received): 27
FYI: the service manual recommends regular greasing with Stens Sten Mix High Temp (red). You grease at the join where the chute rotates on the housing.
melson is online now
