Toro ccr 2450 model 3515 - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 02-23-2015, 02:30 PM Thread Starter
Two issues with this unit. It has been leaking gas - which from reading online appears to be a bad carb? or maybe even a bad gas tank?
Also - used it this weekend and it does not throw the snow far enough out of the snow blower. No blockage or any issue like that. Blade is turning ok - but seems like maybe it does not have enough power Any thoughts?
tlo2009 is offline
post #2 of 12 Old 02-23-2015, 02:40 PM
Likes (Given): 1885
Likes (Received): 663
hello tlo, welcome to SBF!! check the carb, fuel line and gas tank for the fuel leak. to throw snow the paddles have to be in good shape, there ies a small hole on the paddles. thats the wear indicator, sounds like your paddles need replacing and replace the scraper bar while you are at it
post #3 of 12 Old 03-03-2015, 05:52 PM Thread Starter
Thanks - I did not know the paddles were that important! They are 8 yrs old, so I will replace them. I will also check what you advised on the fuel leaks.
Thanks again.
tlo2009 is offline
post #4 of 12 Old 03-03-2015, 05:59 PM
Likes (Given): 1885
check the belt also
the paddles are very important on a single stage snowblower and the number one reason for poor throwing performance
post #5 of 12 Old 03-03-2015, 06:24 PM
Thanks (Given): 30
Thanks (Received): 40
Is the gas leaking down from the tank, the fuel line wet ? or leaking out the bowl gasket ? Do you have the plastic carb or the metal carb ?
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #6 of 12 Old 03-03-2015, 06:32 PM
Thanks (Given): 17
Thanks (Received): 11
Likes (Received): 12
welcome from the Garden State
Toro Snow Commander
Toro Powerlite
joee5 is offline
post #7 of 12 Old 03-04-2015, 05:16 AM
Likes (Given): 1885
that model number should be 38515
post #8 of 12 Old 03-04-2015, 11:28 AM Thread Starter
Thanks.
tlo2009 is offline
post #9 of 12 Old 03-04-2015, 11:41 AM Thread Starter
Not sure where the leak is - I think a plastic carb. Does it matter?
Also, if I need paddles, carb and scraper bar, should I just consider a new unit? I live in Cincinnati, OH and we typically don't a get ton of snow, except of course for the last two years. And I have a long driveway and bad back, so I need one. This unit has not been all that great. I am kind of interested in a unit with the circular metal blades. Most of my neighbors seem to use them and they look like they are much more efficient.
tlo2009 is offline
post #10 of 12 Old 03-04-2015, 11:41 AM Thread Starter
Yes -thanks on that model number - I fat fingered that one.
tlo2009 is offline
