Crank Pulley - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-26-2015, 05:12 PM Thread Starter
Thanks (Given): 80
Thanks (Received): 17
Likes (Received): 15
Crank Pulley
I have been looking to find the correct answer but have come up with 2 so far....
Question: What is used to secure the pulley on the output shaft of a 7hp Tec.
Answers - 1) Set screws on the shaft from the pulley
2) Set screws on the saft from the pulley AND a bolt run in the end of the crank.
96 Mustang - Race car
2005 Mustang - Daily Driver
15 Grand Cherokee Altitude - Mall Crawler
2007 Anderson Open Deck 19ft Trailer
1998 828D John Deere
1996 828D John Deere
2015 D110 John deere
ST724 Ariens not sure of year
1978 Ariens 924000
1964 10ML60D
Duff Daddy is offline
post #2 of 4 Old 02-26-2015, 05:38 PM
Likes (Received): 6
Most of the time I use both if I can. Some cranks are not tapped for a bolt. Roger
rhenning is offline
Thanks Duff Daddy thanked for this post
post #3 of 4 Old 02-26-2015, 08:27 PM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
To throw another answer at you it may possibly be a split sheave that has a key made in to the casting. In this design the shafted is stepped and a bolt on the end of the shaft clamps the two halves in place against the step. No set screws required.
This type of split sheave looks like this. I have seen these on 5-8 HP Tecumseh engines.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #4 of 4 Old 03-06-2015, 10:54 PM
Likes (Given): 103
Likes (Received): 21
Many of the older Tecumseh's just use a slide on fit with a bolt and washer on the end of the shaft to keep them from sliding off.
~Ray~
~1975 Canadiana 1026 Heavy Duty w/light & limited slip differential (& custom exhaust (need to fabricate manifold), customized impeller housing, removable chute in about 5 sec) (currently out of service)
~ Craftsman 8/25 Trac-Drive C950-52671 (mid 80's ???) (current user) (replaced blown engine with original, now in service again)
~ Craftsman 12/32 OHV 71-52112-1 (now in service)
~Noma GP 1028EL (repaired and serviced for daughter to use)
RAYAR is offline
