factory keyed wheel setup or pin-on axles ? Ariens 10ML35 wheel mod - Snowblower Forum : Snow Blower Forums
post #1 of 1 Old 02-28-2015, 07:55 AM Thread Starter
Thanks (Received): 17
Likes (Received): 79
the solid tires on my Ariens 10ML35 are worn nearly smooth. rather than just put chains on them, I am considering an upgrade to pneumatic tires.
the decision then becomes, should I buy and install the factory 10M Ariens triangular 3 bolt hubs with factory tires, that are keyed to the axle ?
OR just buy aftermarket pneumatic tires/axle tubes/rims that are all one piece like the solid tires are, and just pin or bolt them on with one cross bolt on the outside of axle ? this would mean removing the key from the axle keyway and not utilizing the keyway to turn the wheels.
I noticed later model solid axle machines with pneumatic tires often do not have a differential, and the axle tubes are not keyed to the axle shaft. they just put one bolt or pin through the outer hub/axle that does both things- holds the tire on, and transfers the torque to the wheels.
the factory setup uses a keyway to transfer torque, and a cotter pin on the outside of wheel to hold the wheel on the axle shaft
1967 S-242 Snowbird 4/24
Gilson 55012 8/26 gear drive
Ariens 910010 8/32
Cub Cadet 268 8/26
Yard-Man Snowbird 7040-0 5/22
Ariens 10M-L35 3.5/24
greatwhitebuffalo is offline
