Craftsman 536.881750 7.5 HP B&S engine - Snowblower Forum : Snow Blower Forums
post #1 of 1 Old 03-02-2015, 02:43 PM Thread Starter
I've been having a problem with my snow blower where it would run perfectly fine, but after 15 mins of use it will stall and may or may not restart until cooled.
I drained the gas out and put in premium gas. Changed the oil replaced a brand new carburetor, gas cap, and spark plug.
After this the same issues occured so I decided to replace the coil pack. After replacing the coil, the engine is super loud and is shaking. I also see the carburetor spitting gas. The first thing i noticed after installing the coil was the primer bulb was flat. Now it's back to normal shape and when I press the primer bulb i see gas spitting out where the choke adjustment door is located. Is that normal?
Any help is appreciated. Thank you in advance for taking the time in reading this!
Snowman91 is offline
