Snowbird 7040-0 eats a few impeller pins like candy... - Snowblower Forum : Snow Blower Forums
post #1 of 24 Old 03-02-2015, 05:00 PM Thread Starter
Thanks (Received): 17
Likes (Received): 79
well we live, we learn...the impeller roll pin fell out on the Snowbird today. dug through the hardware can, and found a stainless 1/4" fine thread bolt, and nylon self locking nut. installed that.
the machine snapped it off and spit the bolt parts out somewhere....never did find them...
ok you little bugger, dig in the hardware can again, found a HARDENDED ALLEN HEAD bolt, coarse thread 5/16" diameter, and a self locking nut for that. threaded that on. took a few pics to show "it's fixed now"
ran the machine a little more, it promptly SNAPPED THAT OFF TOO. !!
ok that means war...stopped by the hardware store and bought a hardened 5/16" roll pin, a clevis pin with matching lock pin, and a hardened 5/16" coarse nut self locking. one of these has to work.
figured try the roll pin first being that's what was in there before. from working with them before I know they are very hard and nearly impossible to break, to shorten them you have to grind them down.
this roll pin is a lot longer than oem so hopefully it will grab some material on the side too. it should stay put. tapped that in and hopefully it won't shear that off ??
good fun...but I'm just wondering, why alluvasudden is it breaking these ?
1967 S-242 Snowbird 4/24
Gilson 55012 8/26 gear drive
Ariens 910010 8/32
Cub Cadet 268 8/26
Yard-Man Snowbird 7040-0 5/22
Ariens 10M-L35 3.5/24
greatwhitebuffalo is offline
post #2 of 24 Old 03-02-2015, 05:13 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
I think it's because your engine is on backwards
I'm not familiar with the breakdown of that impeller; is there slop in the bushing/bearing allowing the impeller to smack off of the housing somewhere?
('87 Toro 38150 826)
post #3 of 24 Old 03-03-2015, 07:13 AM Thread Starter
no play there, but I think the problem is, there is slop in the roll pin holes both sides, on the impeller, from age and wear. there's a slight amount of slop on the roll pin hole in the shaft itself. a few thou when inserting a 5/16" bolt. it should be tight and not wiggle at all.
the impeller bangs around against the roll pin. or whatever is put in there as a pin. that gives it a head start enough to break them off.
the new roll pin was already bent, and starting to fall out and all I did was run the machine in place, didn't even blow any snow with it yet.
the roll pin the previous owner had in there, was also loose when I got it, but he has a small screw with nut and washers on each side of the roll pin, through middle of roll pin- so as it moved back/forth it would be caught and held in place by the washers.
I may have to do that to get it to stay there. or find a very strong hitch pin like the hardened type used on trailer towing hitches, that won't snap off.
in the meantime I removed the new roll pin, coated it with super glue gel adhesive, and drove it back in there.
if you ever want really strong "locktite" that stuff is it. I've put it on threads before, and when disassembled years later, it take heat from a torch to get it to release. otherwise it will rip the threads off the bolt as it's unthreaded. one time a bolt snapped in half before it released. that's just how strong it is on threads.
Ariens 910010 8/32
Cub Cadet 268 8/26
post #4 of 24 Old 03-03-2015, 07:38 AM
Likes (Received): 42
Can you drill both to a larger size for a larger pin? MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #5 of 24 Old 03-03-2015, 08:02 AM Thread Starter
I could drill it to 3/8" pin size. but that would start to make the drive shaft thinner. if that shaft breaks the machine is a dead player.
the insane part is, it broke off a hardened allen bolt/nut, and a stainless bolt/nut. holy cripes !!
if it drops the roll pin, I'm going to try a grade 8 bolt.
Ariens 910010 8/32
Cub Cadet 268 8/26
post #6 of 24 Old 03-03-2015, 09:04 AM
Another option may be to fill both holes with weld, then re drill to spec. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
post #7 of 24 Old 03-03-2015, 09:10 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
Welding and drilling sounds like the best bet.
post #8 of 24 Old 03-03-2015, 09:18 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
Agreed... although the holes must be drilled in *exactly* the right place.
Or... assuming there's one pin, or two with one in front of the other... how about drilling new holes in the impeller 90 degrees away from the existing ones?
ELaw is offline
post #9 of 24 Old 03-03-2015, 09:25 AM
Thanks (Given): 173
Likes (Given): 457
Likes (Received): 1032
Just drill new holes in the original size, a little way from the old holes. You keep putting bigger, hardened bolts in there and soon you won't have to worry about them breaking. You'll be looking for a new set of gears.
Likes Blue Hill liked this post
post #10 of 24 Old 03-03-2015, 10:59 AM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
+1 If I kept snapping bolts, especially hardened bolts, I would ask my self why. IMHO, instead of putting in bigger and stronger bolts and pins I would be trying to find the root cause. Shear pins are the weakest link for a reason. They are meant to be sacrificial to fail before something more major (and expensive) gets damaged. Just sayin'
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
