Toro 621QZR not starting - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 03-04-2015, 01:05 PM Thread Starter
Hope someone can help me, i think its the spark plug that needs replacing?
I bought it about 15 months ago, it took me through all of last winter no problems and this winter so far no problems.
Last week, i started it, it started ok, as I started taking off the choke as it was warming up, it sputtered and shut down. After much trying, I got it to start up again couple times, but it would just sputter and die after running 10-15 seconds no matter where i had the choke.
I stopped trying to start it after it made a gunshot noise and a spark came out of the exhuast (i'm guessing this is a backfire). I let it sit, shovelled by hand, and started it up the next day, it started ok, I let it run for a couple minutes and it was ok, turned it off and figured it was just one of those things. Maybe I had flooded it or something.
Tried using it again yesterday, it started ok, but again when it was warming up, i was taking off the choke and it started sputtering, than it made the gunshot noise again, spark out of the exhaust and I was not able to get it to turn on again (manual pull or electric start), tried again this morning, nothing
the gas is ok, its from Dec (supreme, no ethanol, with fuel stabilizer) I am not doing anything differently, i've been using it for 15 months, i know how the choke works etc, the gas is not old, I changed the oil the start of this winter season
spark plug gone?
mactruck is offline
post #2 of 13 Old 03-04-2015, 01:16 PM
Thanks (Given): 178
Likes (Given): 467
Likes (Received): 1045
Try'takinmg the plug out and see if it is gettimg spark.
Read your owner's manual troubleshooting section.
post #3 of 13 Old 03-04-2015, 01:20 PM Thread Starter
Yes i read the owners manual, it doesn't say anything to help, i was hoping to benefit from someones experience here, it would be appreciated
mactruck is offline
post #4 of 13 Old 03-04-2015, 01:26 PM
Likes (Given): 1888
Likes (Received): 668
hello mactruck, welcome to SBF!! when was the last time your toro had a tuneup, oil change, carb clean
post #5 of 13 Old 03-04-2015, 01:42 PM Thread Starter
no tuneup, i bought it dec 2013, last year I used it 5 or 6 times. so maybe 4 or 5 hours of use
i changed the oil myself beginning of this season, i've used it maybe 2 or 3 hours this season before this problem started happening
mactruck is offline
post #6 of 13 Old 03-04-2015, 02:07 PM
Likes (Received): 42
Hi Mactruck
Welcome to the Forum. Sounds like your gas may be contaminated with water. It needs a richer mixture to stay running due to bad combustion, thus the need for choke. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #7 of 13 Old 03-04-2015, 02:23 PM
Likes (Given): 1888
did you leave old gas in the tank
post #8 of 13 Old 03-04-2015, 02:34 PM Thread Starter
Originally Posted by motorhead64 View Post
Hi Mactruck
but the gas can is always sealed and the blower always has the cap on it, there is no way for water contamination
i got it running without the choke being on (choke on, turn on, blower warmed up, slowly took choke off, blower was fine), but as it was the day after the original snow storm and i didn't need it, i turned the blower off
than when it snowed again yesterday, bam, backfire as i was slowly letting the choke off and now i can't start it at all, no matter where the choke is
mactruck is offline
post #9 of 13 Old 03-04-2015, 02:35 PM Thread Starter
nope..the gas was purchased in dec, premium, no ethanol with fuel stabilizer, same gas thats been fine all winter
mactruck is offline
post #10 of 13 Old 03-04-2015, 02:53 PM
Thanks (Given): 178
Likes (Given): 467
Try replacing your plug. It's possible it may be breaking down.
