rewind starter repair - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 03-07-2015, 08:15 PM Thread Starter
Hello, i'm new to the forum. I'm thinking about replacing the rewind starter, i bought the snowblower used, it was already broken. There are no screws or bolts with this one… I would like some tips on replacing the rewind starter…
thanks in advance
engine: briggs & stratton 900 snow series
ID:	45689   Click image for larger version
energy is offline
post #2 of 6 Old 03-07-2015, 08:48 PM
Thanks (Given): 173
Thanks (Received): 340
Likes (Given): 479
Likes (Received): 848
Are there parts diagrams for your engine, which might help show how it goes together?
You could remove the shroud it's mounted to (probably what I'd start with). Alternately, you could try drilling out the rivets, but that seems a bit extreme/premature, without at least removing it first to see what's hidden.
post #3 of 6 Old 03-07-2015, 09:00 PM Thread Starter
thanks for helping… i have attachéd the pdf for all the parts
energy is offline
post #4 of 6 Old 03-07-2015, 09:04 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
You just need to remove the plastic above the shroud and the one to the left. their are 2 or 3 fastener's holding the blower cover on. Its not that bad to get off.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #5 of 6 Old 03-07-2015, 09:08 PM
have fun
Likes Grunt liked this post
post #6 of 6 Old 03-10-2015, 01:51 PM
Thanks (Given): 14
Thanks (Received): 17
Likes (Given): 36
Likes (Received): 31
Originally Posted by 43128 View Post
Great Video! Bad design IMHO. The old Tecumseh's used to have 3 little sheet metal screws. You could remove the starter assembly in about 15 seconds.
This isn't too bad, but it's a bit of work to just replace a rope.
250cc B&S (1150 ft lbs)
Loco-diablo is offline
