Tecumseh HMSK 100 will not idle - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 03-10-2015, 02:13 PM Thread Starter
Likes (Received): 14
I have a Tecumseh hmsk 100 on my noma snowblower. It runs only at high speed no matter where I move the throttle. It will not run at slow speed. Was wondering what is causing this? All the linkages seem to be in correct position. Any help would be greatly appreciated. Thanks, Dave.
Dave9354 is offline
post #2 of 15 Old 03-10-2015, 02:19 PM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I'm a little unclear on the question: are you saying it runs fast regardless of whether it's set to fast or slow, or that it dies or runs poorly at low speed?
If it runs fast all the time, something in the throttle linkage may be stuck - can you post a photo of the linkage (there are quite a few different ones)?
If the engine "tries" to slow down but won't stay running or has other problems at low speed, it's most likely the carburetor.
ELaw is online now
post #3 of 15 Old 03-10-2015, 02:30 PM
Buy a carb on ebay/Amazon. About 25-30 bucks.
Pythons37 is offline
post #4 of 15 Old 03-10-2015, 02:31 PM Thread Starter
It stays running at high speed if I move the throttle to high or low speed. It does not stop running at all. All the linkage to throttle and governor are all moving. Nothing is stuck. Never touched any linkages since I bought machine brand new about 15 years ago. I will see if I can post a picture of linkage.
Dave9354 is offline
post #5 of 15 Old 03-10-2015, 02:36 PM
Thanks (Given): 11
Likes (Given): 19
If the actual throttle plate on the carb is moving and the engine speed is not varying, pretty much the only possibility is that the throttle plate inside the carb has come off. That's pretty rare but it does happen.
You should be able to check by (with the engine not running) opening the choke fully, and looking inside the carburetor while moving the throttle plate by hand. You should see the throttle plate opening and closing the passage at the far end of the carb. If all you see is a rotating shaft with a slot and two holes in it, your throttle plate has gone AWOL.
Best bet in that case would be to replace the complete carb, but you also have to figure out where the throttle plate went. If you're lucky it's stuck in the intake manifold or port. If you're less lucky it is inside the cylinder or head or went through the engine.
ELaw is online now
post #6 of 15 Old 03-10-2015, 02:56 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1740
I think if the throttle plate came off and it went full throttle it would have thrown the connecting rod right through the starter.
I'd still check it out with a flashlight to see if you can see a plate and if it's moving.
Pictures of the linkage will be helpful when you have a chance.
post #7 of 15 Old 03-10-2015, 03:04 PM
Thanks (Given): 11
Likes (Given): 19
Good point!
Although I can say from personal experience (when I was young and stupid and fooling with engines that cost me around $0) that it is definitely possible to run a Tecumseh (or Briggs) engine at wide open throttle for minutes at a time without ventilating the block.
It's also possible (although even less likely than the throttle plate coming off in the first place) that the plate lodged somewhere where it restricts flow.
Another possibility is that the idle-speed screw is cranked in so far that "idle" is the same as "fast". That's pretty unlikely to happen unintentionally though.
ELaw is online now
post #8 of 15 Old 03-10-2015, 03:23 PM Thread Starter
Throttle plate is intact.
Dave9354 is offline
post #9 of 15 Old 03-10-2015, 03:49 PM
Thanks (Given): 30
Thanks (Received): 40
On YouTube, Doneyboy73 has a video on how to fix this condition, the cause and remedy, for Tecumseh engines that develope this. It may or may not be this problem, but this is worth a look.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
Likes Grunt liked this post
post #10 of 15 Old 03-10-2015, 05:19 PM Thread Starter
Thanks for the video pathfinder13. My throttle plate is a little loose, not as much as the video. I will try the fix tomorrow and let you know if that was the problem.
Dave9354 is offline
