This winters repairs/mods. - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 03-12-2015, 05:14 PM Thread Starter
Likes (Received): 11
Since joining this forum in Feb and getting a lot of snow i have replaced the pull cord (broke), replaced the drive axle and pinion sprocket bushings, tached the engine and adjusted the carb, done the impeller mod, adjusted the friction disc for a faster reverse, changed the oil to 5-30 synthetic, made some drift cutter bars and I just completed a chute mod.
The chute mod really confines the discharge snow stream a lot. The snow I tested it in was large granule ice at 35 degrees so it was heavy. I could fill a wheelbarrow with how directed the stream is. But the one handed cell phone pic doesn't show it.
The inspector in the second to last pic seems to approve of the project.
ID:	46746   Click image for larger version
ID:	46754   Click image for larger version
ID:	46762   Click image for larger version
ID:	46770   Click image for larger version
ID:	46786   Click image for larger version
1978 Ariens 924032 Teardrop repowered with a 1992 Tec 8 hp.
Ken05 is offline
Likes Loco-diablo, Albert279 liked this post
post #2 of 10 Old 03-12-2015, 05:50 PM
Thanks (Given): 592
Thanks (Received): 773
Likes (Given): 4377
Likes (Received): 1744
You sir, have been busy !!
post #3 of 10 Old 03-12-2015, 06:24 PM
Love the chute mod!
legalsnow is offline
post #4 of 10 Old 03-12-2015, 07:09 PM
jermar's Avatar
Thanks (Received): 14
Likes (Received): 14
Lost a friction wheel, [on order] ordered new pull cord. Will replace fuel line w Tygon. POR 15 epoxy for rust spots. A busy spring/
jermar is offline
post #5 of 10 Old 03-12-2015, 07:12 PM Thread Starter
Originally Posted by legalsnow View Post
Love the chute mod!
Thanks. Need to try it in some powder to see how it performs. It really showed some promise in the heavy stuff.
Might have to cut and re-weld the base to get it more vertical.
Ken05 is offline
post #6 of 10 Old 03-12-2015, 07:13 PM Thread Starter
Yeah - that wheel is toast!
Ken05 is offline
post #7 of 10 Old 03-15-2015, 03:04 PM Thread Starter
The often coveted before and after pics.
ID:	47225   Click image for larger version
Ken05 is offline
post #8 of 10 Old 03-15-2015, 06:21 PM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Did you make the new chute yourself? If you did, how did you get that nice graceful curve in it? English wheel?
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #9 of 10 Old 03-15-2015, 06:34 PM
Likes (Given): 103
Likes (Received): 21
Looks like a chute from another machine added on.
~Ray~
~1975 Canadiana 1026 Heavy Duty w/light & limited slip differential (& custom exhaust (need to fabricate manifold), customized impeller housing, removable chute in about 5 sec) (currently out of service)
~ Craftsman 8/25 Trac-Drive C950-52671 (mid 80's ???) (current user) (replaced blown engine with original, now in service again)
~ Craftsman 12/32 OHV 71-52112-1 (now in service)
~Noma GP 1028EL (repaired and serviced for daughter to use)
RAYAR is offline
post #10 of 10 Old 03-15-2015, 06:39 PM Thread Starter
I modded the base with a cut and weld and then added a plastic upper chute from another machine. The pics at the top of the thread show some of this.
Ken05 is offline
Thanks Blue Hill thanked for this post
