Goes Backwards in 2nd gear - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 03-13-2015, 07:38 AM Thread Starter
Thanks (Given): 9
Likes (Received): 15
I have a Craftsman 25" 8hp identical to this photo. Bought it second hand from a guy who fixes them. It must be fairly old but works well and is well built. Starts on first pull (I use TCW3 2 stroke oil in the gas.)
My question is this: I have never had a first gear and sometimes in second, if on a slight incline, the blower moves backwards under power. I suspect the friction wheel is not aligned properly on the drive plate via the gear selector. I replaced the friction wheel thanks to Donyboy73 and his videos, but cannot find anything on how to adjust the position of the friction wheel relative to the gear selector position on the handlebars. I would suspect I am missing a speed at the other end - that one is not that important to me. In heavy snow, I would like to use 2nd gear but it does not always work right. Any help would be appreciated. Thanks in advance. Great forum!
Taurus04 is offline
post #2 of 14 Old 03-13-2015, 07:40 AM Thread Starter
Thanks (Given): 9
Taurus04 is offline
post #3 of 14 Old 03-13-2015, 07:44 AM
CarlB's Avatar
Thanks (Received): 35
Likes (Received): 81
Can't tell much from the photo, but, look for any type of adjuster between the gear change lever and the point it goes into the tractor portion of the snow blower. your will have to move the friction disk more towards center in neutral. When in neutral the disk should hit dead center on the drive disk.. If you can post some photos of the gear shift rods that might help.
CarlB is offline
post #4 of 14 Old 03-13-2015, 07:44 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
What happens in other gears?
I think you're on the right track thinking the speed-control setup is misadjusted, although going backwards in 2nd would be a pretty severe misadjustment!
It would be helpful if you could phost photos of the linkage from the control lever down to the wheel-drive gearbox, and remove the gearbox cover and post photos of its innards - preferably with the speed selector in neutral. Or halfway between "1" and reverse if there's no specific neutral position.
I'm wondering if something is rigged wrong, or possibly the linkage rod between the speed control lever and gearbox is bent.
ELaw is offline
post #5 of 14 Old 03-13-2015, 08:00 AM Thread Starter
Thanks (Given): 9
I will get some better photos this weekend. 20-40cm of snow coming on Saturday night. I suspect it is mis-adjusted as the fellow that sold it to me said no one ever uses first or second anyway and the friction wheel was in bad shape when I replaced it. Love the machine. This year was a real test as we have a real winter this year.
Taurus04 is offline
post #6 of 14 Old 03-13-2015, 02:11 PM
Thanks (Given): 587
Thanks (Received): 766
Likes (Given): 4349
Likes (Received): 1734
Welcome to the forum Taurus
What is the model number of it ??
post #7 of 14 Old 03-13-2015, 08:45 PM Thread Starter
Thanks (Given): 9
Model number is C950-52677-7.
Taurus04 is offline
post #8 of 14 Old 03-13-2015, 09:01 PM Thread Starter
Thanks (Given): 9
Might as well add another question to my first. I found a manual online that specifies Sunoco Prestige 740AEP grease for auger gearbox. Any idea for equivalent in today's product? I might as well look into that whe I try to adjust the friction wheel alignment.
Taurus04 is offline
post #9 of 14 Old 03-14-2015, 09:53 AM
Thanks (Given): 587
Likes (Given): 4349
I don't know the equivalent for the Sunoco product but using "00" grease would be a good idea. It's just slightly thicker than oil but thinner than what you think grease is. It's used for lubricant in most riding mower geared transaxles. It's good protection. It flows better at cold temps where grease seems to just clump and stick in one spot.
Name:	00 grease 7-06612.jpg
post #10 of 14 Old 03-14-2015, 05:53 PM Thread Starter
Thanks (Given): 9
I think you are bang on for the 00 grease. I have never seen it here, but then again I haven't looked too hard. In Canada we have Canadian Tire and Princess auto. We also have NAPA and CarQuest. Am I on the right track or should I go to the one power equipmant repair depot I know of?
Taurus04 is offline
