Maintenance Report - compression - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 03-15-2015, 09:55 AM Thread Starter
Thanks (Given): 14
Thanks (Received): 17
Likes (Given): 36
Likes (Received): 31
So as I've posted recently, I was having issues with my ariens 921012 trigger wheel lock. After replacing the cable it worked for a while, but started failing again. To make a long story short, I had my dealer look at it.
In addition to the wheel lock issue, I asked him to go through the whole unit.
So her performed his standard snow blower service.
This included plug, oil, carb kit, lubrication all around. It also needed a new friction disc. I was surprised to hear that all my belts were good after 6 seasons of use. I would guess that proper pulley tension and alignment since new would contribute to belt longevity.
My report states compression to be 85lbs which according to his report was marked OK. Therein lies my question. What is normal or acceptable compression for this B&S 250cc snow series engine? At what point is compression bad and what causes compression to decrease over the years?
Thanks in advance.
250cc B&S (1150 ft lbs)
Loco-diablo is offline
post #2 of 13 Old 03-15-2015, 10:05 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1739
Normal wear and tear will lower compression but if it's only 6 yeas old that would need to be a lot of wear on the piston rings or valves/valve seats.
Did you notice any lack or loss of power this last season ??
I didn't look up the spec.
Maybe it has lower compressing during testing because of a compression release built into it for easier starting ??
Thanks Loco-diablo thanked for this post
post #3 of 13 Old 03-15-2015, 10:14 AM Thread Starter
Thanks (Given): 14
Likes (Given): 36
So that's my question. Is 85psi considered low? Or is that normal for this engine?
I haven't noticed any loss of power at all over the years. It's a good strong engine. The machine easily cuts through 2/3+ foot hard drifts that the giant plows leave at the end of my driveway on my busy street. I was throwing snow in excess of 30' all winter.
I should mention I didn't report any engine issue to the dealer, he checks it and lists it on the work order as part of the tuneup
post #4 of 13 Old 03-15-2015, 10:52 AM
Thanks (Given): 589
Likes (Given): 4358
If you posted the engine numbers maybe someone can find the service manual for it and the specs.
post #5 of 13 Old 03-15-2015, 11:01 AM Thread Starter
Thanks (Given): 14
Likes (Given): 36
Thanks Frog
15C1 34 0128 E8
I poked around online and couldn't get a straight answer. I guess this engine does in fact have a compression release built in. I read that because of the release, the actual compression numbers are skewed at best during the compression test.
post #6 of 13 Old 03-15-2015, 01:47 PM
Likes (Received): 6
Most rope start small engines have a built in compression release system to aid in starting. They have to be running at more than 800 to a 1000 RPM for the release to stop working. I doubt you can pull the cord that fast. The number you get pulling it over will never be real compression figures to the point I would never bother even taking a compression test. If it has some compression it is probably enough. Roger
rhenning is offline
post #7 of 13 Old 03-15-2015, 08:09 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3335
Likes (Received): 679
Thanks Frog
15C1 34 0128 E8
Here is a link to the Briggs service manual. Page 27 recommends using a leak down tester to test for any compression problems. Actual compression readings will vary because of the quality of the gauges used and as stated, the automatic compression release (ACR). I have had engines with 50-60 pounds compression run perfectly.
post #8 of 13 Old 03-15-2015, 08:25 PM
Likes (Given): 103
Likes (Received): 21
A leak down test will also indicate where the problems are, valves, rings, head gasket.
~Ray~
~1975 Canadiana 1026 Heavy Duty w/light & limited slip differential (& custom exhaust (need to fabricate manifold), customized impeller housing, removable chute in about 5 sec) (currently out of service)
~ Craftsman 8/25 Trac-Drive C950-52671 (mid 80's ???) (current user) (replaced blown engine with original, now in service again)
~ Craftsman 12/32 OHV 71-52112-1 (now in service)
~Noma GP 1028EL (repaired and serviced for daughter to use)
RAYAR is offline
post #9 of 13 Old 03-16-2015, 02:27 PM Thread Starter
Thanks (Given): 14
Likes (Given): 36
Thanks for all the replies folks!!
Loco-
post #10 of 13 Old 03-16-2015, 04:54 PM
Thanks (Received): 48
Seeing as how Briggs & Stratton has never published compression numbers no one ever checks them with a compression tester (and to be totally honest it isn't really possible to anyway)
Briggs & Stratton has always stated (unless something changed recently) to manually spin the engine backwards, when it hits the compression stroke the flywheel should rebound sharply, if so the engine has adequate compression.
You can't test them going ahead as the compression release cam will lower your numbers, this is why you can't really use a gauge, there's no way to turn the engine over backwards long enough to get a number.
94EG8 is offline
