Grinding valve stems - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 03-17-2015, 05:22 PM Thread Starter
Thanks (Given): 15
Likes (Received): 14
I thought maybe I'd contribute an idea to SBF, since you guys have been so helpful to me.
I've restored power to two Tecumseh motors this season by grinding the valve stems for proper clearance. The issue with doing that is how to get a controlled grind that's flat across the stem. The solution I came up with was to drill a 1/4" hole through a piece of wood and clamp it to my drill press table. Then offset the table a bit and use a cheap grinding wheel with arbor in the drill press. Push the valve up through the center hole in the table and you can get very controlled pressure on the valve stem.
I think it's simpler than setting up a v-block and grinding against the side of your bench grinder wheel.
Craftsman 5/22 with impeller mod & poly skids,
Ariens 28+ Deluxe 921037 AX291
Dave C is offline
Post Thanks / Like - 2 Thanks, 3 Likes, 0 Dislikes
Thanks classiccat, KennyW in CT thanked for this post
Likes classiccat, scrappy, Grunt liked this post
post #2 of 13 Old 03-17-2015, 07:04 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Good idea Dave!
A "lil' bit" fancier than my emery cloth!!
('87 Toro 38150 826)
post #3 of 13 Old 03-17-2015, 07:28 PM
Thanks (Given): 16
Likes (Received): 9
I used a flat file, worked great for me
Ariens1976 is offline
post #4 of 13 Old 03-17-2015, 10:25 PM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Neat idea Dave!
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #5 of 13 Old 03-18-2015, 03:34 AM
Likes (Given): 103
Likes (Received): 21
That's too much messing around for me, I just free hand them on the side of a bench grinder wheel. I also know how to keep them square.
~Ray~
~1975 Canadiana 1026 Heavy Duty w/light & limited slip differential (& custom exhaust (need to fabricate manifold), customized impeller housing, removable chute in about 5 sec) (currently out of service)
~ Craftsman 8/25 Trac-Drive C950-52671 (mid 80's ???) (current user) (replaced blown engine with original, now in service again)
~ Craftsman 12/32 OHV 71-52112-1 (now in service)
~Noma GP 1028EL (repaired and serviced for daughter to use)
RAYAR is offline
post #6 of 13 Old 03-18-2015, 06:35 AM
Thanks (Received): 35
Likes (Received): 81
That's exactly what i do.
CarlB is offline
Likes RAYAR liked this post
post #7 of 13 Old 03-18-2015, 12:06 PM
Thanks (Given): 121
Likes (Given): 269
Likes (Received): 6
I like it !
eyeboltman
Eyeboltman is offline
post #8 of 13 Old 03-18-2015, 05:33 PM
Originally Posted by eyeboltman View Post
i like it !
x 2
OldAriensRuleNewEngland is offline
post #9 of 13 Old 03-19-2015, 10:18 AM
Likes (Received): 36
I just bring them into work and set up on a surface grinder. Set up, grind, and break down takes less than 5 mins. Perfect length and perfectly square. Nothing like having the right tool for the job.
JJG723 is offline
post #10 of 13 Old 03-19-2015, 10:19 AM
Still a great set up Dave!
JJG723 is offline
