Troubleshooting Craftsman 3/20 SS - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 03-22-2015, 10:50 AM Thread Starter
Likes (Received): 27
Picked up a Toro 2450 and craftsman 3/20 (both SS) for $50. Seller said craftsman was filled with fresh mix. Both started and ran when I bought them.
Had a couple of inches of slop yesterday, and decided to try the craftsman. With maybe 4 pumps of the primer, it ran for a few seconds and died. Part and full choke did not make a difference. This happened more than a half dozen times.
Will assume for the moment that this is more likely an issue with fuel than a problem with ignition. I think the primer bulb is delivering gas, but once that runs out it dies. Doubting it is an issue with a fuel line, or even the primer would not help. Thinking the issue will likely be with the carb.
Any thoughts / ideas before I start troubleshooting?
Toro 3650 (primary)
Toro 2450 (recent purchase)
Toro PowerLite (3hp)
Craftsman 3/20 (also recent, will likely flip)
Toro 1800 electric (gone)
Shovels (and aspirin)
time2time is offline
post #2 of 5 Old 03-22-2015, 11:41 AM
Thanks (Given): 172
Thanks (Received): 336
Likes (Given): 476
Likes (Received): 835
Sounds like a fuel issue, as you said. Gas can get to the carb, since the primer helps. I'd assume the carb is clogged due to old gas sitting in it, and needs to be cleaned.
post #3 of 5 Old 03-22-2015, 11:41 AM
Likes (Received): 42
Agee...sounds like. The carb. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #4 of 5 Old 03-22-2015, 12:10 PM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
+1...Drop the bowl and you will probably see crud in there.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #5 of 5 Old 10-14-2019, 06:17 PM
Anyone have an Idea for this 3/20 bowl gasket? What is the motor similar to as in a snapper? Sears does. it show it in its parts list obviously.
followup: found one at local tractor repair/sales! actually any "dealer" would have it.
Dael V Escher is offline
