Putting a 16hp single on 2 stage - Snowblower Forum : Snow Blower Forums
post #1 of 33 Old 04-04-2015, 06:29 PM Thread Starter
Likes (Received): 12
Just like it says....for some reason im obsessed with snowblowers....i was going to attempt anyway to put a predator 670cc(22hp) v twin on one of my ariens...its a an 8/24...just wondering what if any mods need to be done...i believe the hsmk 80 motor has a 1 inch shaft just like the 22hp...i have the engine sitting around and the idea just dawned on me...im just wondering if ill need to get bigger pulleys or if anyones ever built a modified one what was their thoughts?
Thanx
SNOWJOB1125 is offline
post #2 of 33 Old 04-04-2015, 06:55 PM
Likes (Given): 1891
Likes (Received): 670
hello Snowjob, welcome to SBF!! geno built an ariens with 20hp v twin Honda motor on it
post #3 of 33 Old 04-04-2015, 07:33 PM
Likes (Received): 1384
ALOHA from the paradise city.
post #4 of 33 Old 04-04-2015, 07:42 PM Thread Starter
Thank you for welcoming me. Im in MA, so theres plenty of snow to be thrown up here.. Ya, I just wanna start a new project and i figured this may be a fun one...wanna see what it'll do with a 22hp motor behind it...im gonna do it all over once i know it fits...sandblast, paint, led's, etc..why not? right?
post #5 of 33 Old 04-04-2015, 07:46 PM
it helps us out if you put your local under your name.
post #6 of 33 Old 04-04-2015, 08:14 PM
Thanks (Given): 178
Thanks (Received): 345
Likes (Given): 483
Likes (Received): 852
That sounds pretty awesome Though I'd want to use a wider bucket if trying an engine that big.
I had an 824, now I have a 1024 Pro. I observed the 10hp engine bogging under heavy loads, but at the end of the season, I discovered that the governor was not actually opening the throttle all the way, even when the RPM dropped by 500 to 3100.
I replaced the governor spring, it held RPM better during some testing at the end of this season. I'll see how it performs next year. But with the governor working better, it did a better job of making use of the engine's available power. I still couldn't make the throttle plate open fully, even driving into 24" of wet snow.
Which makes me wonder how much of a benefit you'd see by going to 20hp, with a 24" bucket. It would offer more if you went to a larger engine pulley, of course, speeding up the auger and impeller. But you have to be mindful of overworking them.
post #7 of 33 Old 04-04-2015, 08:28 PM
Likes (Received): 483
Welcome to SBF SNOWJOB1125, I'm in CT.
As stated on a prior post, Geno built one with a large engine, I think he'll be the best member of the forum to guide you thru the process.
I have an HSMK80 engine and it has a 3/4" shaft, if that is the case you will need new pulleys (I'd go slightly larger on the auger pulley to increase the impeller tip speed). I would think that the crankshaft would seat higher on the 22HP engine, if that is the case you will need longer belts (if possible I would increase the width of the belt). You may have to change the engine to frame mounting hardware. You may have to find or build a larger belt cover. You may have to reinforce your driveshaft bearings or bushings. You may have to modify the chute control.
Keep us posted as your project comes along (it is always good to post pictures).
post #8 of 33 Old 04-04-2015, 08:56 PM
snowjob1125, search for the thread post a couple snowblower pic's for me?
post #9 of 33 Old 04-04-2015, 10:05 PM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
With a 22hp V twin I would find a nice machine with a 32+ inch wide bucket or larger. Anything smaller would be a waste of all that power
GustoGuy is offline
post #10 of 33 Old 04-04-2015, 11:56 PM
Thanks (Given): 592
Thanks (Received): 773
Likes (Given): 4377
Likes (Received): 1744
Welcome to the forum Snowjob
https://www.snowblowerforum.com/forum...r-pics-me.html
