Honda HS80 Help - Snowblower Forum : Snow Blower Forums
post #1 of 23 Old 04-11-2015, 08:58 PM Thread Starter
TOTHEMAX's Avatar
Honda HS80 Help
Hello,
I have an Honda HS80 that I cannot get adjusted properly. When I got it it wouldnt go into reverse but would go in all 3 forward gears. By adjusting the gear select cable I got it to go into every gear and it worked well. Only issue is It will not free roll while in neutral. There is a second cable next to the gear select cable that adjusts slack to the wheel that makes contact with the friction disc. No matter what I do I cannot get it to free roll in neutral.
Any help?
Ford ST726
TOTHEMAX is offline
post #2 of 23 Old 04-11-2015, 09:59 PM
Likes (Received): 10
that is a tracked model correct?? (one at work is..) only thing i can think of might be the tension of the tracks themselves??? if im not mistaken there is an adjustment for that... maybe somebody else with more experience with those can chime in
1984 Columbia 10hp-33in
2015 Columbia 420cc 28in 3xHD
Marty013 is offline
post #3 of 23 Old 04-11-2015, 10:23 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
Track models are notoriously difficult to move, unpowered.
post #4 of 23 Old 04-13-2015, 07:05 PM Thread Starter
TOTHEMAX's Avatar
Yes it's tracked. It's a pig to move while not running. you might as well just start it and move it in gear.
Now I just found the gear select cable busted. I called the local honda dealership and they couldn't find the part number in the system. They also called honda direct and they don't even show it. Guess the unit is over 20 years old and they haven't made the cable in a while.
I can't even find the number online. The semantics I found all have cable #15 not even listed.
http://www.jackssmallengines.com/Jac...nda/26158/5959
TOTHEMAX is offline
post #5 of 23 Old 04-13-2015, 08:15 PM
take it to a small engine shop (the cable itself) and see if they have something for a motorcycle or any other machine that might work... best hope i can give you right now
Marty013 is offline
post #6 of 23 Old 04-13-2015, 08:48 PM
Likes (Given): 467
Likes (Received): 483
Boats.com]All Years HS80 TA Honda Snowblower CONTROL PANEL Diagram and Parts does not show the cable available either. I agree with Marty on trying to match one up with at a motorcycle shop or try to find a good used one.
Adjusting the transmission cables has a special procedure, I will try to read my HS80 service manual for the proper procedure and i will post it. (I had an HS80 that I bought with an intermittent no drive condition, I followed the proper procedure and all was good forward and reverse gears).
YSHSfan is online now
Thanks TOTHEMAX thanked for this post
post #7 of 23 Old 04-13-2015, 08:56 PM
db9938's Avatar
Partstree has a few offerings, depending on your serial number.
Honda HS80 TAS - Honda Snowblower, Made in Japan, SN: SA1-1000001 CONTROL PANEL Diagram and Parts List | PartsTree.com
post #8 of 23 Old 04-14-2015, 08:54 AM Thread Starter
TOTHEMAX's Avatar
The serial number on it is SA1-100xxxxx
I think this may work!
Ford ST726
TOTHEMAX is offline
post #9 of 23 Old 04-14-2015, 09:08 AM Thread Starter
TOTHEMAX's Avatar
I'm going to order that cable and 2 skid shoes. This machine is in pretty **** good shape it just sucks the parts are drying up!
Ford ST726
TOTHEMAX is offline
post #10 of 23 Old 04-14-2015, 02:21 PM Thread Starter
TOTHEMAX's Avatar
Nooooooo! I ordered the part and I just got an email from parts tree informing me the part is no longer available. Time to research some More.
TOTHEMAX is offline
