Ground Issue? - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 04-25-2015, 05:44 PM Thread Starter
Thanks (Given): 66
Thanks (Received): 19
Likes (Given): 139
Likes (Received): 28
Ground Issue?
I've got a great Tecumseh that I am having what I think is a ground issue. When I disconnect the wire from under the shroud (from the points) to the throttle ground connector by the carb, I have spark. When connected, no spark/no run.
I'm guessing I'm grounding out under the shroud. I think the fix is to pull the shroud and find the ground and repair, or simply replace the wire.
Do you agree?
gsnod is offline
post #2 of 4 Old 04-25-2015, 05:54 PM
Thanks (Received): 48
Yes.
94EG8 is offline
post #3 of 4 Old 04-26-2015, 07:24 AM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
Just need to find out if it's a bare spot on the wire of something wrong with the throttle.
post #4 of 4 Old 04-27-2015, 04:46 PM Thread Starter
Thanks (Given): 66
Likes (Given): 139
Yep, I agree. I'll pull the shroud and see what I see. The wire is the original, so probably needs replaced anyway. I'll start there and see if that fixes it.
gsnod is offline
