Briggs 8 HP using oil - Snowblower Forum : Snow Blower Forums
post #1 of 26 Old 04-26-2015, 08:35 PM Thread Starter
Likes (Received): 9
I have a '78 Toro 826 with a Briggs model 190402. Last winter I had to add oil every 2nd time I cleaned the driveway. I tore it down to put fresh rings in it and lap the valves this weekend and found slight to medium play in the valve guides - exhaust is the worst. What do I do now? If it goes another 2-3 years, that's OK with me or I may even sell it this fall.
michigansnowbird is offline
post #2 of 26 Old 04-26-2015, 11:44 PM
predator 412cc repower, you might be able to drill out the current guides and install inserts, if not it probably wont last much longer. i would probably fix it the way i described for now and when it gets really bad replace it with the predator
post #3 of 26 Old 04-27-2015, 07:41 AM Thread Starter
Likes (Received): 9
Do you need special tools to insert guides?
post #4 of 26 Old 04-27-2015, 08:53 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
Can the guides be knurled on a small engine ?? Short of replacing a valve guide knurling on an automotive head is pretty common during a rebuild.
post #5 of 26 Old 04-27-2015, 10:29 AM Thread Starter
Likes (Received): 9
That's a good question. I suppose I should call a machine shop about that. I talked to a small engine shop that says they don't repair the engine when they find worn guides. They also said they've got used b&s 8 HP engines for $150.
post #6 of 26 Old 04-27-2015, 01:56 PM
Likes (Given): 1882
Likes (Received): 663
i woild be looking at the 301cc predator motor
post #7 of 26 Old 04-27-2015, 02:50 PM
Thanks (Given): 589
Likes (Given): 4358
That's the problem with a small engine, the labor to repair if you're paying out of pocket just doesn't make sense. The parts are usually bad enough.
post #8 of 26 Old 04-27-2015, 04:40 PM Thread Starter
Likes (Received): 9
The machine shop claims they can put inserts in for $12 per valve. Seems cheap to me. I figure I'll let them take a look at and do it if they don't see any other obvious problems. If things start getting expensive, I'll probably slap it back together and run til its totally dead.
post #9 of 26 Old 04-27-2015, 07:54 PM
Thanks (Received): 40
Likes (Received): 149
It sounds believable. There are special tools to ream the stock block then the inserts just press in. I don't hear of it being done that often but it's an age old process.
Spectrum is offline
post #10 of 26 Old 04-28-2015, 08:30 AM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
Hopefully that is all that is needed to repair the engine. I used to have an old Briggs that puffed oil and rather than dump money into it I replaced it. If you can repair it for a reasonable cost go for it and if it works well than it is money well spent.
GustoGuy is offline
