Lil help - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 04-28-2015, 09:57 PM Thread Starter
Likes (Received): 12
Lil help
Ok so i have a new motor for my project...i need a new double pulley for the shaft..The old shaft is 3/4 and new motor is 1'. The dimensions of the new motor are 1' shaft, 2-3/4 long, 1/4 keyway. Anyone know or have a rough idea of what kind of pulley i need? Just a 1' double pulley or are there more variables? Thanks.
SNOWJOB1125 is offline
post #2 of 8 Old 04-28-2015, 10:14 PM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
The new one has to have the same outside diameter as the old one. That's the important thing.
Also the belt grooves have to be the same width.
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #3 of 8 Old 04-28-2015, 11:57 PM
Likes (Received): 483
The distance between the V groves has to be exactly the same and when the motor is install, they have to be properly aligned with the transmission and auger pulleys.
For the transmission belt I would use a pulley with the exact outside diameter as the one from the old engine (so that the ground speed will remain the same).
For the auger belt I would do some calculations to get a impeller tip speed of 4000 - 4500 ft/min. (IMHO at this speed you will have the best performance of the impeller).
I found this at another forum:
Tip velocity is calculated:
impeller diameter inches / 12 = impeller dia ft X 3.14 = impeller circumference ft X impeller rpm = tip velocity ft/min.
If you are calculating the other way for needed rpm for a desired velocity with a known impeller diameter then first find the circumference of the impeller in feet:
diameter inch/12 = diameter ft (d below)
pi x d = circumference in feet
velocity/circumference = rpm
Say you have a 20" dia impeller you want to run at 4200ft/min
20"/12 = 1.67' x 3.14 = 5.24' circumference, then:
4200/5.24 = 801.5 rpm needed
Some may now see that their 20" impeller (a fairly common size impeller) straight driven from a 540 pto will be running at 2824ft/min tip velocity...somewhat shy of what others recommend (4000 - 5000ft/min) to throw snow REALLY far.
BTW Willl, the post you quote is sometime back in the development of this project. I have since discovered I have a 14" impeller not the 12". I'm now looking at a 2:1 540 rpm pto increaser to get impeller to 1080 rpm to get 3956ft/min.
14/12 = 1.167 x 3.14 = 3.66 x 1080 = 3956ft/min
When you find the desired rpm then you can do the calculation for the needed diameter of the outer engine pulley (for the auger belt).
I hope it makes sense.
By the way there is a Toro Powershif 28" with this engine upgrade on CL, it may be helpful to contact him for any tips if needed.
Toro snow thrower 16 HORSEPOWER
post #4 of 8 Old 04-29-2015, 04:51 AM
You don't need a double pulley. You can use 2 single pulleys often, plus it gives you a bit more flexibility.
post #5 of 8 Old 04-29-2015, 06:51 AM
+1 on that.
post #6 of 8 Old 04-29-2015, 11:22 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1740
What specifically is the make and model of your "project" ?
If you're replacing the engine with a similar horsepower it's best to stick with a same size (diameter) pulley but if you're going bigger than you can use some of that extra power to put a slightly bigger pulley on.
post #7 of 8 Old 04-29-2015, 11:40 AM
I am thinking that his project is the NOMA 12hp33" from the previous thread ("Ok so step one is complete...i managed to score a pretty decent shape NOMA 33' 12hp").
4 extra HP, therefore my suggestion on a possibly larger impeller belt pulley based on impeller tip speed calculation results (for engine shaft).
post #8 of 8 Old 04-29-2015, 06:50 PM Thread Starter
Yes thats the snowblower im putting it on...im gonna start ripping it apart this friday...i never even thought to use 2 pulleys...awesome..dont know why i didnt think of it...i texted that guy with the toro and he lucked out and had a 1' pulley stock on his..so he used the original
