HELP! Cub Cadet Gear Box Leaking Red Fluid??? - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 05-01-2015, 09:28 AM Thread Starter
The guy at the shop told me it was just grease breaking down and to just find someone with a grease gun??? say what? it is just a very sloooooooooow leak, and the fluid is definitely red. coming right out of the bottom... like the seal has failed or something... any ideas?
The snow blower is only 6 mos old (if that matters).
Thank you in advance.
HalleluYAH is offline
post #2 of 10 Old 05-01-2015, 10:06 AM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
Welcome to the forum HalleluYAH
Well, a lot of stuff matters and even in a particular brand like Cub Cadet there can be various things that get changed from one machine to the next.
When asking about your blower you should always state the model numbers and if the engine, the engines model numbers.
If it's leaking, it's leaking and it shouldn't be. If it's six months old it should be covered under warranty.
post #3 of 10 Old 05-01-2015, 05:43 PM
Thanks (Received): 143
Likes (Received): 297
Agreed, that should still be under warranty. If you post up the model number of the machine, we can verify if there is a gasket or just a sealant.
post #4 of 10 Old 05-01-2015, 06:58 PM
since it only 6 months old return that mtd for a refund and buy an ariens. i wouldnt mess with it if its only 6 months old anyways
post #5 of 10 Old 05-03-2015, 05:49 PM
AL-
Thanks (Given): 7
If your grease is a high-temp grease it could turn into a liquid if it got hot enough to reach its drop point but they normally designed for high temperatures. Also normally they turn back into a solid when they cool. does it leak out even when the gear case is cool ?
I'm no expert but you might want to check out synthetic oil as an option if needed as I don't think they have a drop point and are good for high temperatures. I have used a low temp (-40F) Valvoline brand that I got at Advance Auto
AL- is offline
post #6 of 10 Old 05-05-2015, 08:04 AM
Wonder what happened?
Pythons37 is offline
post #7 of 10 Old 05-05-2015, 08:40 AM
Thanks (Given): 72
Thanks (Received): 398
Likes (Given): 184
Likes (Received): 931
Its only been a few days..he might still be back.
post #8 of 10 Old 05-05-2015, 09:12 AM
Thanks (Given): 591
Likes (Given): 4374
I think in some cases it's because you don't select notification when setting up your account and you get a reply or reply's and are not notified.
I think it should default to daily as I've been in that situation where I wasn't paying attention when setting up and some time down the road revisited a forum and found reply's . . . . opps.
post #9 of 10 Old 05-08-2015, 03:44 AM
Likes (Received): 1384
ALOHA from the paradise city.
post #10 of 10 Old 05-18-2015, 08:45 AM
Likes (Given): 48
Likes (Received): 74
Originally Posted by 43128 View Post
since it only 6 months old return that mtd garbage for a refund and buy an ariens. i wouldnt mess with it if its only 6 months old anyways
The last Ariens that I bought new was garbage! Problems can happen on any machine.
Cub Cadet 2X 524 SWE
caddydaddy is offline
