Carriage bolts for scraper bar - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 05-03-2015, 10:17 PM Thread Starter
Thanks (Given): 14
Likes (Given): 44
Likes (Received): 50
I think there 5/16 but maybe 3/4" long. My ace and local hardware store had nothing shorter than 1.25". The carriage bolts for the scraper blade on my 10000 series ariens. Didn't check hd, or lowes. Where do u find these
Rob711 is offline
post #2 of 10 Old 05-04-2015, 02:46 AM
I think mine were 1". I just took an angle grinder with a cutoff wheel and cut them flush with the nuts. Otherwise look around, somewhere had to have shorter ones.
post #3 of 10 Old 05-04-2015, 04:59 AM
Thanks (Given): 587
Thanks (Received): 766
Likes (Given): 4349
Likes (Received): 1734
Can't say for sure but it's time to try Menards or Home Depot.
post #4 of 10 Old 05-04-2015, 07:06 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
Am I remembering correctly those are 1/4" bolts? If so, McMaster-Carr has them down to 1/2" length: McMaster-Carr If they're 5/16" they have those too but I think the shortest is 3/4". Available in stainless too if you'd like them not to rust.
ELaw is offline
post #5 of 10 Old 05-04-2015, 11:44 AM
AL-
AL-'s Avatar
Thanks (Given): 7
Likes (Received): 29
In our nearby city there are two locally owned smaller stores that sell mostly nuts and bolts. also there's a hardware store with a "Do it Best " franchise that has 1/2"and up in 1/4" and 5/16 in stainless, but not in galvanized. I'm not sure if this isn't just the local owners option. It's not part of the stores inventory because some outside outfit does the stocking.
AL- is offline
post #6 of 10 Old 05-04-2015, 11:58 AM
Likes (Received): 483
I got them from repairclinic.com.
post #7 of 10 Old 05-04-2015, 01:01 PM Thread Starter
Thanks (Given): 14
Likes (Given): 44
Thanks all, I will try lowes, if not I'll cut them. It didn't dawn on me to cut them after I install them! So simple, duh
Rob
Rob711 is offline
post #8 of 10 Old 05-05-2015, 02:18 AM
AriensProMike's Avatar
Thanks (Received): 19
Likes (Received): 58
5/16"x1". McMaster carr is cheap. But you have to buy 100 peices. I also get them with the nylon lock bolts. You get a lifetime supply for $10 bucks.
AriensProMike is offline
post #9 of 10 Old 05-05-2015, 06:57 AM
Spectrum's Avatar
Thanks (Received): 40
Likes (Received): 149
The bolts are usually 5/16-18 X 3/4" short neck carriage bolts. I have them here.
Pete
Spectrum is offline
post #10 of 10 Old 05-30-2015, 06:47 AM
Likes (Received): 345
Pretty much always use a cutoff wheel on the ones I used.
HCBPH is offline
