10hp tecumseh MTD snow blower seized while running - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 05-16-2015, 12:29 AM Thread Starter
so I had finally gotten the thing started after about 30 pulls and a wire brush to the spark plug in -8c weather, I let it warm up for 5 minutes and as I was walking up to begin the battle it slowly stalled, I didn't hear any strange noises or clunks. I went to pull the starter rope again and it wouldn't budge. it has oil but is just a hair over full.
I tried penetrating oil in the cylinder but that didn't help...
I took the pull starter off but couldn't find a socket that fits on the flywheel nut with a breaker bar, im going to pick up a socket tomorrow, I think its just a 1 inch. and just tonight pulled the belts off, ive heard people saying to try turn it over by the drive shaft but couldn't find a place to fit a socket except the tiny bolt at the end. any suggestions or things to try would be really appreciated. Thanks
edit: I think it around 8 years old
llllll is offline
post #2 of 5 Old 05-16-2015, 06:38 AM
Thanks (Received): 48
Sometimes the bolts back out of the stator allowing it to jam in the flywheel. Pull the flywheel and take a look behind it.
94EG8 is offline
post #3 of 5 Old 05-16-2015, 08:20 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1740
Welcome to the forum IIIIII
post #4 of 5 Old 05-16-2015, 03:18 PM
i would check that to, ive also seen the stators snap right off. did it stall suddenly or did it gradually stall?
post #5 of 5 Old 05-18-2015, 04:17 PM
Likes (Received): 9
Check for up and down play in the crankshaft. I had the same thing happen on a 6 HP tec. Worn journal on rear of motor caused crank to jam up.
michigansnowbird is offline
