In-line fuel filter? - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 06-23-2015, 09:33 PM Thread Starter
Got an old Monkey Wards MTD with an 8 hp B&S motor.
Would it be worth it to put an in-line filter on the fuel line?
Right between the belt guard and the carb?
Yes or no?
BillyM is offline
post #2 of 13 Old 06-23-2015, 10:16 PM
Thanks (Received): 143
Likes (Received): 297
Not a bad idea. I might add a fuel shut off, up stream to the filter. That way it makes changes less messy, and for those extended periods without snow, but not end of season, you can run the carb dry.
And at the end of the season, simply disconnect the down stream side of the filter to drain the fuel from the tank.
post #3 of 13 Old 06-23-2015, 10:18 PM
Thanks (Received): 41
Likes (Received): 98
true that! and while your at change out the rubber fuel lines
scrappy is offline
post #4 of 13 Old 06-23-2015, 11:41 PM Thread Starter
It does have a shut off right under the tank.
Thanks guys.
BillyM is offline
post #5 of 13 Old 06-24-2015, 08:49 AM
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1742
I put a shut off and fuel filter on everything that doesn't come with one.
Likes Grunt liked this post
post #6 of 13 Old 06-24-2015, 11:13 AM
Likes (Received): 483
Definitely a good idea.
post #7 of 13 Old 06-24-2015, 05:01 PM
Same here. My dear old dad bought a Toro self pace twin blade mower. Has a Briggs on it with no shut off. There is no space to add a shut off, so I looped the fuel line around (and below the tank nipple). After 20 min the fuel filter would empty, and stall out. Cannot figure out why, so removed shut off and all is good.
Hard to believe a $1000.00 mower does not have a shut off. Another plus for my 28 yr old Honda HR21.
scrappy is offline
post #8 of 13 Old 06-24-2015, 08:06 PM
Thanks (Given): 37
Thanks (Received): 70
Likes (Given): 116
Likes (Received): 146
I put a shut off on everything that doesn't come with one.
Lol....Trying hard to refrain from an ill timed wife joke...
2009 Honda HS928WAS
2005 Honda HS520AS
1996 Honda HS621AS
2012 Toro 1800 Power-Curve
Freezn is offline
post #9 of 13 Old 06-24-2015, 08:45 PM
Is the engine set up anything like this? Maybe there is a knock out in it or a place to drill in one of the covers.
post #10 of 13 Old 06-25-2015, 12:58 AM
https://www.youtube.com/watch?v=NqBMzCJ3164
Not even close, its a vertical shaft. Here's a product link. I can get a real pic this weekend. Puzzles me that it will not flow fuel with a loop of hose not kinked and below the fuel tank.
Toro | Timemasterâ„¢ Walk Power Mower
scrappy is offline
