Carb Cleaning - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 07-02-2015, 11:14 AM Thread Starter
Carb Cleaning
I can't seem to remove the carb from the engine. It looks decently gummy on the outside. Would it be ok to just clean the carb from the outside? I cleaned the float, needle valve, and the power adjust screw. I sprayed into the carb with the carb cleaner.
(I also learned that getting carb cleaner on your skin really hurts!)
EnjoyLife is offline
post #2 of 4 Old 07-02-2015, 11:22 AM
Likes (Received): 483
There are various air passages inside the carb that need to be cleaned out, if you can it is always better to remove the carb for cleaning.
post #3 of 4 Old 07-02-2015, 11:57 AM
It really depends on how bad it is. Sometimes all that is needed is to remove the bowl and clean out the bowl and the nut for the main jet.
post #4 of 4 Old 07-02-2015, 12:12 PM Thread Starter
Thanks. I definitely cleaned the main jet nut and the little hole at the end. Hopefully, this will be ok. Cross my fingers!
