Toro 38050 drive belt install - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 07-06-2015, 08:31 PM Thread Starter
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 173
I am new to the forum, just starting to work on some lawnmowers and snowblowers. I recently picked up (for free !!) a 1980 Toro 724. After cleaning out alot of varnish (the owner said it has sat for 20 years in his garage, I think the whole time with gas), I got the motor running pretty well. I then noticed that the belts were very dry. The auger belt comes off easy, but I am struck on the drive belt. The shaft for the auger idler arm assembly is very close to the drive pulley (see picture) and is preventing a simple removal. The operator manual just says slide the idler pulley out of the way (I actually removed it) and then just "remove the belt". I may be able to force it out, but I am thinking that I am missing something simple. Any ideas?
paulm12 is online now
post #2 of 14 Old 07-06-2015, 08:36 PM
The side of the frame looks like a tight fit as well. Does moving the idler arm bracket back and forth change anything?
Thanks paulm12 thanked for this post
post #3 of 14 Old 07-06-2015, 08:55 PM
you just force it between the rod it wont hurt it. on these snowblowrs you dont have to remove the lower pan to replace the belts, you just slip it in between the pulleys and into the pulley groves
post #4 of 14 Old 07-07-2015, 11:12 AM Thread Starter
Thanks (Given): 63
Likes (Given): 277
Shryp: there isn't much slop for the bracket, like the rest of the machine it is built pretty rugged.
43128: that's what I'll try today. And I removed the pan just to inspect the pulleys, pads, etc (and to learn a bit more about these machines).
post #5 of 14 Old 07-07-2015, 04:16 PM
Likes (Received): 1383
YOU are going to have to split the blower in halfsees . ALOHA from the paradise city.
post #6 of 14 Old 07-08-2015, 01:20 AM
Likes (Received): 9
Some older Toros I have had to split to change the belts. After removeing top and middle bolts, you might be able to just loosen the bottom bolts to let it hinge apart withought completely separating it.
wheelhorseboy is offline
post #7 of 14 Old 07-08-2015, 12:23 PM Thread Starter
Thanks (Given): 63
Likes (Given): 277
Thanks all for the insights. I did manage to change both belts, without splitting the blower. But I did have the bottom plate off, which made it much easier to get the loose belts exactly where they needed to go. I can now see how splitting the blower may make it quicker, especially if I had to do in cold weather.
Now on to lubing the gears, cleaning the friction disc, and buttoning back up. Then some fresh gas and a test drive.
Thanks again.
post #8 of 14 Old 07-09-2015, 12:03 PM Thread Starter
Thanks (Given): 63
Likes (Given): 277
Followup: is there a deflection amount for the drive belt? the guides just say to remove slack. Any rule of thumb you guys have learned over the years?
thanks
post #9 of 14 Old 07-09-2015, 02:45 PM
THE pulley for the drive belt should tight up to it. or as I like to say snug as a bug in a rug.
post #10 of 14 Old 07-09-2015, 10:36 PM Thread Starter
Thanks (Given): 63
Likes (Given): 277
and the obligatory picture, all cleaned up and ready for covers to go on. Thanks members for the resources and the replies.
Likes Grunt liked this post
