Clean Carburetor or Simply Replace? - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 07-08-2015, 08:39 PM Thread Starter
Hey guys. Hope you guys enjoying the blistering summer that we have. Someone shoot me.
Anyway, I took apart my snow blower's carb for the first time. I should have dismantled it higher up than where I did. The gasket that sealed the connection between the carb and the engine crumbled apart.
I was looking up a replacement gasket which I found to be $5. And, the rebuild kit with new washers is about $10. But, then I noticed that a completely new carb is only $14!!
So, why am I cleaning the carb?
Wouldn't it just be easier to just buy a new carb and replace the old one?
Also, how are the aftermarket carbs? They got great reviews so I'm assuming they're ok.
Thanks again for the help, guys.
EnjoyLife is offline
post #2 of 13 Old 07-08-2015, 08:45 PM
Thanks (Given): 78
Thanks (Received): 166
Likes (Given): 407
Likes (Received): 645
i would be VERY leary of a $14 complete carb.
post #3 of 13 Old 07-08-2015, 10:00 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
Used an aftermarket carb (8hp Tec) for the first time yesterday. Works Fine. Only Complaint is the holes in the side for the airbox mounting bracket were not tapped. The carb I used had the 2 adjusment screws rather than the troublesome emissions type carbs with no tuning capabilities. I'll get a few more to have on the shelf. $19 on fleabay IIRC.
Jackmels is online now
post #4 of 13 Old 07-08-2015, 10:06 PM Thread Starter
There are a couple of carbs on Amazon. They vary in price from $14 to $20. Much cheaper than than the $90 and they got good reviews.
post #5 of 13 Old 07-13-2015, 09:27 AM
Likes (Received): 345
I've used more than one Oregon carb in the past with good results. Biggest thing is get one with the same throttle linkage and choke linkage as the original.
I've even had to swap a couple of parts from the original carb to the replacement one before, went just fine.
If I have a questionable carb, I replace it as it's usually cheaper and easier than dealing with a finicky carb but that's just me.
HCBPH is online now
Likes Kiss4aFrog, gr0uch0 liked this post
post #6 of 13 Old 07-13-2015, 09:59 AM
Thanks (Given): 581
Thanks (Received): 759
Likes (Given): 4291
Likes (Received): 1710
What he (HCBPH) said.
Likes gr0uch0 liked this post
post #7 of 13 Old 07-17-2015, 02:45 PM Thread Starter
Replacing Carb is Better
Just wanted to let everyone know what happened when I tried cleaning my carburetor for the first time.
First, I tried cleaning it. Spent a couple of hours getting the various parts and cleaners. And, it didn't turn out so well. The engine ran funny. I wasn't sure since this is my first snow blower but it just didn't seem right. So, I ended up replacing it. Guess what? The engine started on the first pull! And, the engine sounded so beautiful. I didn't realize a snow blower was supposed to sound like this.
The parts to just clean the carburetor (washers and stuff) cost $8 but a new carb was $14. I realized that I should have just replaced it from the start. Would have saved me so much time and aggravation and the engine will probably run better.
CONCLUSION: Don't bother cleaning a carburetor. Carburetors are so cheap. Just replace them!! (unless all you have to do is clean the main jet perhaps every year.)
Likes Grunt, gr0uch0 liked this post
post #8 of 13 Old 07-17-2015, 09:52 PM
Likes (Received): 9
A lot of carburators are not that cheap.
wheelhorseboy is offline
post #9 of 13 Old 07-22-2015, 11:33 AM
CarlB's Avatar
Thanks (Received): 35
I just bought a replacement for a Chonda clone 340 cc 11hp engine from china for 6.99 with free shipping. Works fine.
CarlB is online now
post #10 of 13 Old 07-22-2015, 11:15 PM
Thanks (Given): 37
Thanks (Received): 70
Likes (Given): 116
Likes (Received): 146
What he said. Many carbs including Honda carbs are not cheap. I know it sounds hokey, but I enjoy tearing down carbs and rebuilding them. Kind of therapeutic...lol...
2009 Honda HS928WAS
2005 Honda HS520AS
1996 Honda HS621AS
2012 Toro 1800 Power-Curve
Freezn is offline
