Eska Starter Motor Woes - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 07-14-2015, 07:46 AM Thread Starter
I am still using the Eska Sno-Flyer (Model 945C) my Dad bought in 1976. It is all chain drive and built like a tank. I have only had to rebuild the carburetor, keep up with the rust, and replace a few worn out chains.
While doing some routine maintenance, I checked the electric starter motor (Redmond, W2764A) and noticed that it was sparking a lot and heating up very quickly. I took it apart for cleaning, oiling, and brush replacement.
Well, that is where my woes began. I could not find replacement brushes anywhere and any motor place I took it to scratched their heads and sent my somewhere else. Some thought the brushes were fine, but the armature was defective and therefore the motor was toast. Another told me to replace the front bronze sleave bearing. So, I replaced the front bearing with no change in behavior.
The armature passes the various continuity checks I found on YouTube, so I have ordered some brushes on eBay that I should be able sand to the proper size. Given that the starter motor is almost 40 years old, I am not optimistic that I will be able to repair it well. So, I would like to buy a replacement motor.
Since I don't have any specs on the motor, I don't know what to look for in a retrofit starter. A picture is attached to this thread. All I really know is the following:
Diameter: 3 1/8"
Length: 4 1/4"
Shaft: 5/16"
Distance between studs: 2 5/16"
Can anyone advise me where to find a replacement starter to retrofit into the snowblower? What specs should I look for? What is the likely HP and RPM of the original starter motor?
Your help and advice is greatly appreciated. Thank you.
louye2 is offline
post #2 of 8 Old 07-14-2015, 12:40 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
Welcome to the forum Louye
post #3 of 8 Old 07-14-2015, 02:41 PM
Likes (Received): 9
What engine does your have on it? My Eska is powered by a Tecumseh, but i dont recognize that stater.
wheelhorseboy is offline
post #4 of 8 Old 07-14-2015, 03:57 PM
Likes (Received): 1379
Good luck on that 1. you could always peruse E-bay. ALOHA from the paradise city.
post #5 of 8 Old 07-14-2015, 08:08 PM Thread Starter
My Eska has a 5HP Tecumseh engine in it. I have had no luck finding something on eBay or at Surpluscenter.com. Then again, I don't really know what kind of motor I should be looking for.
Thanks for reading my thread and offering moral support.
louye2 is offline
post #6 of 8 Old 07-14-2015, 08:44 PM
Likes (Given): 215
Likes (Received): 304
Wait. Why does it look like even the starter has a chain gear on it?
edit: I found this. So it is a chain driven starter.
http://www.mytractorforum.com/119-ho...e-starter.html
dbert is online now
post #7 of 8 Old 07-14-2015, 11:22 PM
Likes (Received): 9
Ill see if i cant get mine dug out tomorrow. Am wondering if you could do a flywheel swap to mount a different starter completely.
post #8 of 8 Old 07-20-2015, 08:19 PM Thread Starter
Update
Sorry to have been out of touch. Too many projects to get done this summer. Here's my latest update that may help some folks who are having difficulty finding a starter for their snowblower.
I installed a set of new brushes in the Eska starter motor with no change in behavior i.e. excessive sparking and overheating. I think this motor is toast!
I bought a used servo motor (Electro-Craft #05860012, 30 VDC) at my local electronic surplus store. After modifying the face mount, I attached it to a 24VDC 5A power supply and voila! The little servo motor had a lot of torque and was able to start the 5HP Tecumseh engine. So, I may have stumbled onto a solution to my problem. There is still more work to do to make the installation permanent and cover the motor with something to protect it from the elements. Of course, I won't know for sure until the winter when I try to start the Eska snowblower and the outside temperature is 20 degrees Fahrenheit!
louye2 is offline
Thanks Grunt thanked for this post
Likes Grunt liked this post
