It`s time to start on this one. Some of you may recall, that I picked it up on Craig`s List last winter. It is a 1964, Snow Shark three stage blower, made by Moto-Mower. (24") .
This is what I am starting with.----
First thing I figured I had better do, was to get the Kohler k-141 engine running. The inside of the gas tank, was coated with what looked like petrified honey. The inside of the carb, was plugged solid with the same stuff. I stripped all the parts off the carb.
I had nothing on hand, that was meant for soaking carbs in. Tried some paint thinner and a few other liquids, that I did have, but nothing had any effect. Had a can of After Wash (used on furniture, after the paint stripper is wiped off). I was ready to try anything at this point. As soon as I dipped the carb body into the clear liquid, the clear liquid started to turn brown. In a matter of a few minutes, the carb body was clean as a whistle, inside and out.
I had an additional tank, that was super clean to start with. With that and new gaskets in the carb, I put it all back together. Started right up and runs perfect. Not even a hint of smoke. I wanted to keep the original engine on this blower, so I am pleased that it well only require cosmetics.
Next, I will start taking the whole machine apart and sand blasting as many parts as I can. The bucket and the main frame are one piece, so that makes prepping it for paint a bit more of a challenge. I`ll post info and photos, as I go along with the restoration.
I do have one question at this point. What should the position of the augers be to each other ?? Should one be 1/4 turn ahead of the other, like on a 2 stage blower ?? ---- John
