Craftsman 8.5 hp Briggs and stratton smoking bad - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 08-10-2015, 06:16 PM Thread Starter
I have a Craftsman 8.5 hp B&S 2 stage. I checked the oil level many times and check the clearance on the intake and exhaust valves. The compression is about 90psi when I tested it cold.I removed the valve cover and the reed valve or oneway reed seams to work fine (when I suck air its free flowing and when I blow in it it stops) The thing is it just smokes like crazy out of the breather tube. I cleaned the carb and the float works properly. I google searched this several times and it says it has too much oil in it, Any suggestions.
smoke is offline
post #2 of 15 Old 08-10-2015, 09:29 PM
Thanks (Received): 41
Likes (Received): 98
Sure sounds like oil ring. Need to tear down and inspect bore & valve guide (s) clearance. Set of rings will most likely fix it.
Since I'm not a big fan of briggs, don't bother, just re-power with chonda from HF. That's what they tell everyone with a Tecumseh.
scrappy is offline
post #3 of 15 Old 08-11-2015, 08:10 AM Thread Starter
What's repower with a chonda (Honda )from HF mean?
smoke is offline
post #4 of 15 Old 08-11-2015, 09:02 AM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
I would guess it's rings too. More so if you bought it used and it didn't get the oil changed regularly. If it's not something you'd want to tackle you might find a local high school or votech with a small engine class that might do it for you on the cheap.
chonda (China/Honda)
He's speaking of buying a new Honda clone at Harbor Freight. 6.5 HP (212cc) OHV Horizontal Shaft Gas Engine EPA
NorthernTool has them too. Ironton OHV Horizontal Engine 208cc, 3/4in. (19.05mm) x 2 19/64in. (58.5mm) Shaft | Ironton Engines| Northern Tool + Equipment
post #5 of 15 Old 08-11-2015, 09:31 AM Thread Starter
Is 6.5 hp enough power, from the 8.5 hp I have now? What about the electric start option? That is a good price.
smoke is offline
post #6 of 15 Old 08-11-2015, 11:12 AM
Thanks (Given): 588
Likes (Given): 4353
New engines start very easy even in winter.
If you see some threads in the "re-power" section you'll see most people who have done the swap are very pleased with the power.
For electric start you'd need to spend more $$ and it would likely be a 12V so you'd have to mount a battery or use some kind of jumper in the garage to get it going. And when I say jumper it could be something like jumper cables or it could be a permanent connector wired to the blower and the 12 volt source with a switch.
Buy one of these at an auto parts store and cut it in half. I use them when adding lighting, hand warmers or anything needing a good water resistant connector. They also come in four and five wire. I like them because they are fairly cheap and I can get them local.
Three bucks at Oreilly: List: Search for '47965' | O'Reilly Auto Parts
Walmart, Ebay, Mouser, HomeDepot or anyplace they sell trailer towing stuff could carry them.
post #7 of 15 Old 08-11-2015, 02:58 PM
The HF 8 hp is close to $300. Plus what it will take to adapt it, and has to be re-jetted for cold weather and carb heater box fabbed.
Seriously I would at least remove the head from the Briggs and inspect the bore. If not scored it would be worthy of rings and valve job. It's not rocket science.
scrappy is offline
post #8 of 15 Old 08-11-2015, 04:55 PM
Thanks (Received): 173
Likes (Given): 415
Likes (Received): 664
I'd bet a loonie that the 6.5 clone would out perform the 8.5. and run smoother and quieter.
Thanks help thanked for this post
Likes 43128 liked this post
post #9 of 15 Old 08-11-2015, 06:30 PM
Likes (Received): 12
Now that's a bet I'd be willing to take. The clone engines puts out an incredible amount more torque than the older briggs and tec motors, regardless of being rated a couple horse less. Along with smoother running and much quieter.
My 420cc Predator on my 32 inch Ariens is vastly quieter than the two older Ariens models I have with the old motors.
The electric start was already mentioned, but those motors start effortlessly on the first pul
1971 Ariens 7/24 (retired)
2011 Ariens Deluxe 24
1980 Ariens st7/24 (retired)
1985 Ariens st10/36
SlowRider22 is offline
post #10 of 15 Old 08-11-2015, 07:43 PM
Thanks (Given): 50
Likes (Given): 70
Likes (Received): 137
Nothing better than a multi baffled Honda style muffler on the Predator engines. They are so powerful an quiet you can barely hear them running if you are inside the house. I blow my driveway any time of day and do not have to worry about ticking the neighbors off. The old Tec I got rid of was very loud and poor running engine compared to the 3 Chonda HF Predator 212cc I own.
GustoGuy is online now
